Front panel connector problems
Last response: in Systems
Recently put a cheap computer together and am having some trouble with the front bezel connectors. To test them, I plugged a wireless USB adapter into both connections 1 at a time and the adapter didn't light up for either one. It works fine on the back connectors. I also tried this with a USB mouse. The front panel also has audio ports for microphone and headphones. They don't work either.
I'm using Linux Mint 10, so I wanted to make sure that doesn't have anything to do with the problem. I don't know if front panel USBs require any drivers, though I suspect not.
Can anyone tell me what the possible problems are and if there's anyway to test them? The mATX board only has 2 USB connections in there so I'm pretty sure I have it plugged into the right place. I tried both of them by the way.
Other than this front panel problem, the computer is working fine. I just don't want to go crawling in the back every time I need to plug in a flash drive.
Homebuilt system Master
Did you flip the connectors around on the header panel?
Did you confirm the orientation of the header/connector? On some boards it can be sideways rather than across the header block.
Ask the community
