Solved
Help! - advice to upgrade very old system to newer <$200 ?????
  • Systems
  • Product
Last response: in Systems
February 16, 2011 6:10:22 PM
Hi All,
I've got a very old system (AMD 64 2800+, Asus K8N-e Deluxe, Geforce 9300GT 512 MB, Geil Ram 2.5 GB) that I want to replace with newer (but not necessarily new) hardware (each of the 4 items only) but need to do so for as much less than $200 as possible if possible. I don't need a great performance increase but 30% to 50% (or more) would be great if it's even possible for the price.
Thanks in advance for any help.
Max
More about : advice upgrade system newer 200
Best solution
February 16, 2011 6:32:04 PM
just off the top of my head:
AS Rock 880 GM: $59.99 (back in stock on 2/18)
4 GB DDR3-1333: $39.99
Athlon II X3 450: $79.99
This is $180. Its more than 100% more powerful, though you have to use the on-board video (or keep your 9300). Another $75 would get a HD 5670 or an HD 4850, but that's over your budget.
February 16, 2011 8:37:35 PM
Though if you had enough parts, you could put those old pieces together and sell it on ebay. You'd get at least $50-$90 for the old system. That would be enough for the graphics card.
m
l
February 27, 2011 6:42:55 PM
Best answer selected by LinuxMan2011.
m
l
February 27, 2011 6:45:02 PM
I have now postponed the purchase until APR/MAY so I can increase the available funding to around $300. I'll probably just post the same question but with a higher spendable amount sometime in April.
Thanks,
Max
m
l
