Solved
Need help!!! system will not come on
When I push the power button only the mobo lights come on and I can here a faint beep rechecked all wires everything looks in its right place.no fans just the mobo lights
System
Mobo gigabyte 790fx ud5
Phenom ii 965
Hd 6850
Psu ocz modstream 600w
8 answers Last reply Best Answer
More about need help system
  1. Hello Gooner4lyfe;
    Is this a new build? Or one you've had for a while that's developed problems?
  2. Update I took the video card out and everything boots up, its a 600w psu so I don't know why it won't turn on with it connected. I don't think my card is bad. Any advice would be helpful.
  3. Best answer
    Did you plug the extra power lead into the video card?
  4. Yes
  5. Did you replace the old video card to get booted up?
    What did you use?
  6. I didn't have a gpu installed when everything came on. I'm gonna go to tiger direct tmro and buy a new psu to if that solves. Thank you very much for all your help.
  7. Best answer selected by Gooner4lyfe.
Homebuilt Systems
