I have to remove the 12v 4-pin to start the pc, then reinsert it to POST!
Last response: in Systems
Related ressources:
- ForumNo boot with Gigabyte GA-MA770T-UD3P: 4-pin 12V / CMOS reset
- ForumMobo-CPU fried? Not booting with 12v 4-pin plugged in.
- ForumPC Wont Start With 12v Pin & CPU
- ForumMobo only powers up without the 4pin cpu power plugged in
- ForumWon't turn on with 4pin cable
- ForumBad motherboard or PSU? Won't POST
- ForumP55 UD3 Can't post and constant restart
- ForumThe New System does not even Beep and POST
- Forum4-pin connector problem
- ForumPlease help, info inside
- ForumP7P55D Memroy Problem
- ForumPC Doesn't start after removing 2nd hdd and changing boot order
- ForumMy Computer Won't start !!!
- ForumCpu + 12v running high?
- ForumWon't Post w/ 12v plugged in
- ForumNew Sub $700 build
- Forum[Solved] 4 yr old system: no signal/no post
- Forum[Solved] 2nd Post, 1st Build - <> - Need Help with Crossfire Mobo & Monitor
- Forum[Solved] First Post, First Build, Help with Mobo and Monitor
- Forum2008 System, Ready to Upgrade (25 frames on Crysis 2)
- More resources
