Hi guys,
yesterday I installed my new parts, aswell as my whole windows. I installed all the drivers for the above mentioned mainboard from the gigabyte homepage, aswell all windows updates and the newest graphic card drivers... Everything worked fine - except one thing:
This is my board, and it has, like many others, a Realtek HD Audio Chip installed. When I installed the driver from the Gigabyte homepage, I opened my "Realtek HD Audio Manager" and configured my 5.1 speaker system. Then I tested it with the big blue "Play" button there - and, I happily heard, everything works fine. I tried the same in the "Windows speaker configuration" (the test is pretty much the same, just the sound which the speakers are doing is different), and this worked fine too.
BUT THEN I finally wanted to turn on some music, and I soon took notice that I had no bass at all.... I then remembered that a similar (if not the exact same) problem happened with my old Asus board, which had obviously a Realtek Audio chip too. There the solution was to turn on the option called "
Bass Management" in the Realtek HD Audio Manager. Sadly, I didnt have this option! Well, then, I thought, the most obvious solution should be to upgrade my Realtek HD Audio Driver. I found out that my driver version is not the newest, downloaded the newest version from
here and started the driver installation. At the first time, it said its "deinstalling my old driver version" - then I had to restart. When I was back on, it automatically repeated the installation, now it said its installing the new driver. Then I had to restart once again and when I was back up the HD Audio Manager was in the right bottom task bar again. BUT - I instantly saw that its the exact same driver version as before -_- How do I know? Well - the new version looks pretty much different than the ones before - AND I still had not the option to check I really need to get my sound system running, the "Bass Management".
I then tried different things from 10 pm to 3 am to get this (sorry) s*it driver running:
-) deinstalled the driver through device manager, restarted, reinstalling the new driver.
-) deinstalled the driver through device manager, deinstalled the driver under system panel --> Programs, restarted, reinstalled new driver
-) deinstalled the driver through device manager, deinstalled the driver under system panel, manually deleted everything related to Realtek under C:\, restarted, reinstalled new driver
Between this attempts I installed every windows update, since I thought missing windows updates may cause this too..
Im pretty desperate right now, I hope you can help me
