With the help of a few friends I recently built a new PC. I didn't know much about hardware, so I read a few guides, etc. online and took my time shopping around on Newegg.com. I ran my initial build by a few friends (several of who have built their own PCs before) and they made a few suggestions (mostly just finding better and/or cheaper parts). After double and triple checking everything for compatibility, I ordered everything. This is what I got:
CPU - Intel Core i5-750 Lynnfield 2.66GHz 8MB (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215)
Motherboard - Gigabyte GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128425)
RAM - Corsair XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218)
GPU - Sapphire 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873)
HDD - Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433)
CD/DVD Drive - Samsung DVD Burner (http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188)
PSU - Antec EarthWatts EA750 750W (http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026)
And I've got it all in an Antec 300 case (4 fans total: 2 front, 1 top, 1 back) and I'm running Windows 7 Home Edition.
I assembled my new PC two weeks ago, and, once again, had a friend inspect it to make sure everything was hooked up correctly and he approved of my wiring for airflow and whatnot. It ran fine for a week, but last Saturday I got a BSoD. I can't remember what I was doing at the time, however, it happened again the next day while playing Left 4 Dead 2. When my computer restarted it almost immediately bluescreened again. After a couple more attempts, I started it in Safe Mode where it seemed stable. I shut it down from there and started it back up a while later and everything seemed normal.
Since then, my computer has been bluescreening fairly regularly. Sometimes I can get on and browse around the internet for a while (you know...check email, Facebook, etc.) but eventually it will crash. And usually after it crashes, I can't get back on without it crashing again almost immediately if I'm not in Safe Mode. But it will even crash when I'm in Safe Mode sometimes.
I don't think it has to do with overheating since sometimes it crashes when I'm not really doing much (although that may be a problem...I installed CoreTemp and whenever I play any kind of game my CPU temperature always shoots up to the high 80s or even well into the 90 degC range). I tried to do a system restore, but I could never get one to go all the way through...it would always BSoD in the middle of it. Today, I reinstalled Windows 7 and was successful on the third attempt (once again, BSoD interrupted the other two), but I haven't done anything since then. I plan on reinstalling all my drivers as soon as I get the chance.
Could anyone provide some feedback for what the problem might be? Is there some compatibility issues or known product faults with what I got? Does it sound like a case of bad RAM? Incorrect BIOS settings or some kind of problem with the first installation of Windows? I will post if something new develops or if the second Windows installation seems to make any difference. Thank you for your help!
