Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] AMD dual core 6000+ problems
Forum CPU & Components : CPUs [Solved] AMD dual core 6000+ problems
Best answer from ps3hacker12.
Hey
I've been using this computer for more then a year, it was built overtime. At first I never had problems with the CPU but lately it has been acting up. I play starcraft 2 and around 5 mins of playing I get a huge fps spike and task manager indicates the CPU's usage is around 90% and greater. Also happens when I'm simply browsing.
I've looked up the problem in countless places, yesterday I applied new thermal pasting thinking that is was overheating, not much luck ... i also recently installed 2gb more ram just because I had it around. RM clock suggests each CPU is around 30-45C.
Please help me!!!
CPU-Z TXT Report
Binaries
CPU-Z version 1.57.1
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 6000+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Package Socket AM2 (940)
CPUID F.B.2
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G2
Technology 65 nm
Core Speed 2200.0 MHz
Multiplier x FSB 11.0 x 200.0 MHz
HT Link speed 1000.0 MHz
Stock frequency 3100 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 15.5x
Max VID 1.450 V
K8 Thermal sensor yes
K8 Revision ID 6.0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002008h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 512 KB, 1 thread(s)
CPUID
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00060FB2 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00060FB2 0x00000923 0x0000011F 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x32582034 0x61754420 0x6F43206C 0x50206572
0x80000004 0x65636F72 0x726F7373 0x30303620 0x00002B30
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000007F
0x80000008 0x00003028 0x00000000 0x00000001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000002
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000000
MSR 0xC001001E 0x00000000 0x00000060
MSR 0xC0010015 0x00000000 0x02000040
MSR 0xC0010042 0x31041206 0x0417020E
MSR 0xC0010041 0x00000190 0x0000060E
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02002008h
CPUID
0x00000001 0x00060FB2 0x01020800 0x00002001 0x178BFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
Chipset
Northbridge NVIDIA nForce 560 rev. A2
Southbridge NVIDIA nForce 630a rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 314.3 MHz (CPU/7)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 20
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number 99U5316-033.A00LF
Serial number 6C3808F9
Manufacturing date Week 23/Year 08
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-15-20 @ 333 MHz
JEDEC #3 6.0-6-6-18-24 @ 400 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Part number VS2GB800D2
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
JEDEC #1 4.0-4-4-13-15 @ 270 MHz
JEDEC #2 5.0-5-5-18-22 @ 400 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 70 01 02 00 03 30 45 3D 50 3C 1E 3C 2D 01
20 17 25 05 12 3C 1E 1E 00 06 3C 7F 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 DD
40 7F 98 00 00 00 00 00 00 05 39 39 55 35 33 31 36
50 2D 30 33 33 2E 41 30 30 4C 46 00 00 00 08 23 6C
60 38 08 F9 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 39 39 55 35 33 31 36 2D 30 33 33 2E 41 30 30 4C
DIMM # 2
SPD registers
10 0C 08 30 03 02 00 03 37 50 00 00 32 1E 32 2D 01
20 18 25 05 13 3C 1E 1E 06 00 37 7F 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 0D
40 7F 7F 9E 00 00 00 00 00 01 56 53 32 47 42 38 30
50 30 44 32 20 20 20 20 20 20 20 20 20 20 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 56 53 32 47 42 31 33 33 33 44 33 20 20 20 20 20
90 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model M2N68-AM (0x000001F6 - 0x00ADAC5C)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8712
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8712
LPCIO Revision ID 0x8
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 12 08 11 00 C1 60 01 00 00 01 00 06 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.46 Volts [0x5B] (CPU VCORE)
Voltage 2 3.36 Volts [0xD2] (+3.3V)
Voltage 4 12.35 Volts [0xC1] (+12V)
Voltage 5 -6.21 Volts [0x61] (-12V)
Voltage 8 3.09 Volts [0xC1] (VBAT)
Temperature 0 63ーC (145ーF) [0x3F] (TMPIN0)
Temperature 1 43ーC (109ーF) [0x2B] (TMPIN1)
Fan 0 3199 RPM [0xD3] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 11 00 FF 00 37 FF 07 37 FF 07 40 39 01 D3 FF FF
10 FF FF FF 7F D0 80 80 80 00 FF FF FF FF FF FF FF
20 5B FF D2 FF C2 62 FF FF C1 3F 2B 80 CE F1 F1 F1
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF 2D FF FF FF FF FF FF FF
50 35 18 7F 7F 7F 00 56 56 90 56 FE 12 E0 00 00 00
60 00 19 43 40 8C E1 FF FF 00 19 43 40 8C E1 FF FF
70 00 19 43 40 8C E1 FF FF FF FF FF FF FF FF FF FF
80 00 00 00 00 FF FF FF FF 00 00 FF CA 02 00 99 99
90 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor NVIDIA I/O
Temperature 0 72ーC (161ーF) [0x48] (TMPIN0)
Hardware monitor NVIDIA NVAPI
Voltage 0 1.10 Volts [0x44C] (VIN0)
Fan PWM 0 65 pc [0x41] (FANPWMIN0)
PCI Devices
Description RAM Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0547
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0x44
Caps revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0xDC
Interface type MSI Mapping
PCI registers
00 DE 10 47 05 06 00 B0 00 A2 00 00 05 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 08 83
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
40 43 10 08 83 08 DC E0 01 22 20 11 11 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 15 10 F1
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0D 03 00 00 00 7F 00 00 00
90 70 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 0F 0F 06 00 00 00
D0 20 10 00 00 F0 FF FF FF 00 00 00 00 08 00 01 A8
E0 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0548
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000900
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 48 05 0F 00 A0 20 A2 00 01 06 00 00 80 00
10 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 43 10 08 83 00 00 D0 FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 05 2F 00 3C 01
70 10 00 FF FF C5 80 00 00 00 00 04 19 0C 00 40 00
80 09 20 00 80 01 02 08 D0 00 00 40 01 FF 00 00 00
90 FF 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 10 81 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 30 02 AF 02 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
E0 41 20 E6 24 8B 35 EE 41 0A 44 91 48 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0542
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000CC00
Address 4 (port) 0x00000600
Address 5 (port) 0x00000700
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x0A
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 42 05 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 CC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 06 00 00 01 07 00 00 00 00 00 00 43 10 08 83
30 00 00 00 00 44 00 00 00 00 00 00 00 0A 01 00 00
40 43 10 08 83 01 00 02 C0 00 00 00 00 00 00 00 00
60 01 05 00 00 01 08 00 00 01 0D 00 00 00 00 00 00
70 00 00 00 00 00 00 C8 FE 00 00 FE FE 01 00 00 00
80 00 10 FE FE 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 01 01 00 00 00 21 82 02 02 0D 0D 19 19
D0 40 00 40 01 13 10 14 0A 05 00 00 00 00 00 00 00
E0 80 10 04 10 05 40 00 01 80 2A 80 00 62 44 44 00
F0 02 FF 1E BF 01 00 40 80 10 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x055E
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDBFFF000
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 5E 05 06 00 B0 00 A2 10 03 0C 00 00 80 00
10 00 F0 FF DB 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
40 43 10 08 83 01 00 02 FE 00 00 00 00 00 00 00 00
50 01 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x055F
Revision ID 0xA2
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDBFFEC00
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x16
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 5F 05 06 00 B0 00 A2 20 03 0C 00 00 80 00
10 00 EC FF DB 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 02 03 01
40 43 10 08 83 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 0A 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 04 00
80 01 00 02 FE 00 80 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 44 44 00 00 55 01 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x055E
Revision ID 0xA2
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDBFFD000
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
10 00 D0 FF DB 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
50 00 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
Location bus 0 (0x00), device 4 (0x04), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x055F
Revision ID 0xA2
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xDBFFE800
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x14
Int. Pin 0x02
PCI capability
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
10 00 E8 FF DB 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 14 02 03 01
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
B0 00 11 22 33 44 44 00 00 AA 02 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0560
Revision ID 0xA1
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 60 05 05 00 B0 00 A1 8A 01 01 00 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 43 10 08 83
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 43 10 08 83 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 A8 20 7F 00 FF 20
60 00 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
Description PCI to PCI Bridge
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0561
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB8
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x8C
PCI registers
00 DE 10 61 05 07 04 B0 00 A2 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 40 D0 D0 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
40 00 00 73 07 01 00 02 00 0F 00 00 00 00 00 40 00
50 00 00 00 00 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 02 00 00 5C 18 00 00 00 00 00 00 08 00 01 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 43 10 08 83
C0 43 10 08 83 03 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0550
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000C480
Address 1 (port) 0x0000C400
Address 2 (port) 0x0000C080
Address 3 (port) 0x0000C000
Address 4 (port) 0x0000BC00
Address 5 (memory) 0xDBFFA000
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class 0x12
Caps offset 0x8C
PCI registers
00 DE 10 50 05 07 01 B0 00 A2 85 01 01 00 00 80 00
10 81 C4 00 00 01 C4 00 00 81 C0 00 00 01 C0 00 00
20 01 BC 00 00 00 A0 FF DB 00 00 00 00 43 10 08 83
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 03 01
40 43 10 08 83 01 8C 02 00 00 00 00 00 00 00 00 00
50 1F 68 38 60 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 01 0F 06 42 00 00 00 00
70 2C 78 C4 40 00 00 00 00 02 00 00 08 20 00 20 78
80 08 00 00 80 00 00 00 00 00 00 00 00 12 00 10 00
90 5F 02 00 00 00 00 00 00 03 9F 22 E3 01 01 00 00
A0 6E 5A 00 75 80 00 00 00 00 00 00 00 23 34 00 02
B0 05 CC 86 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 02 A8
D0 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00
E0 00 00 00 00 00 00 3F 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 02 01 1E 00 00 00 00 00
Description Ethernet Controller
Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x054C
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xDBFFC000
Address 2 (memory) 0xDBFFE400
Address 3 (memory) 0xDBFFE000
Subvendor ID 0x1043
Subsystem ID 0x8308
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x50
PCI capability
Caps offset 0x6C
PCI registers
00 DE 10 4C 05 06 00 B0 00 A2 00 00 02 00 00 00 00
10 00 C0 FF DB 01 00 00 00 00 E4 FF DB 00 E0 FF DB
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 01 14
40 43 10 08 83 01 50 02 FE 00 01 00 00 08 00 00 00
50 05 6C 86 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 FF 00 00 00 08 00 03 A8
F0 02 03 00 00 30 00 00 00 02 01 00 00 02 00 00 08
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0562
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
PCI registers
00 DE 10 62 05 07 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 E1 E1 00 00
20 00 DC F0 DF 01 C0 F1 CF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1A 00
40 0D 48 00 00 43 10 08 83 01 50 02 F8 00 00 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 A2 49 00 00
60 08 80 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 01 3D 11 00
90 00 00 01 31 80 25 08 00 C0 01 48 01 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
PCI registers
00 DE 10 63 05 04 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 92 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 08 00 00 00 00 00
Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 82 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 02
90 00 00 11 10 00 05 18 00 C0 01 08 00 00 00 00 00
Location bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 3
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 05 05 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 72 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 03
90 00 00 11 10 00 05 20 00 C0 01 08 00 00 00 00 00
Location bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 4
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 06 06 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 62 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 04
90 00 00 11 10 00 05 28 00 C0 01 08 00 00 00 00 00
Location bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 5
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 07 07 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 52 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 05
90 00 00 11 10 00 05 30 00 C0 01 08 00 00 00 00 00
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0563
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x08
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1043
SubSystem ID 0x8308
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 6
Version 1.0
Physical slot #0
Presence detect no
PCI registers
10 00 00 00 00 00 00 00 00 00 08 08 00 F1 01 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 B4 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 06
90 00 00 11 10 00 05 38 00 C0 01 08 00 00 00 00 00
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 1.02
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 01 00 E4 00 00 00 20 C8 2E 0F 2C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 07 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 3F 01 00 00 00 00 00 00 00 00
80 03 00 E0 00 80 FF EF 00 00 00 00 00 00 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 C0 00 00 0B FE 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
D0 03 10 00 00 00 10 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00
F0 01 40 00 C0 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 00 80 00 00 00 00 00 00 00 00 00
60 E0 3F 78 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 46 00 00 00 00 00 00 00
80 05 00 00 00 00 00 00 00 24 CA 69 5D 20 13 22 00
90 10 08 01 00 6A 00 10 64 39 00 00 80 00 00 00 00
A0 EB 02 00 5D 00 00 00 00 00 00 00 00 00 00 00 00
B0 8B 0A 6D 5D 5E 00 00 00 44 8D 46 00 2E ED EE 86
D0 88 08 0C C0 E0 44 32 98 88 24 08 00 D2 A1 10 50
E0 8C E7 02 68 44 00 1A C8 00 17 07 0C A0 08 19 1A
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF 3B 04 00 40 00 10 0A 00 00 00 00 00 00 00 00
50 F8 E9 A7 E2 DD 00 00 00 00 00 00 00 C0 A3 E7 F1
60 81 00 00 00 21 62 1F 00 C0 00 00 00 00 00 00 00
70 11 01 32 51 21 40 70 50 00 2A 00 08 17 21 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 80 04 00 00 60 81 02 0C 00 00 00 00
A0 92 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 40 0C 25 20 20 00
E0 00 00 00 00 3E 1C 5B 00 19 17 00 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 B2 0F 06 00
Description Audio device
Location bus 1 (0x01), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x1102
Model ID 0x0007
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Subvendor ID 0x1102
Subsystem ID 0x1012
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0xDC
Caps version 1.1
PCI registers
00 02 11 07 00 05 01 90 02 00 00 01 04 00 40 00 00
10 01 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 11 12 10
30 00 00 00 00 DC 00 00 00 00 00 00 00 13 01 02 14
40 00 00 00 00 00 00 00 00 00 00 00 00 00 82 00 00
50 03 80 00 00 FF FF 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 06
Description VGA Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0622
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xDF000000
Address 1 (memory) 0xC0000000
Address 3 (memory) 0xDC000000
Address 5 (port) 0x0000EC00
Subvendor ID 0x107D
Subsystem ID 0x2AC1
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps class Vendor Dependant
Caps offset 0xB4
PCI registers
00 DE 10 22 06 07 00 10 00 A1 00 00 03 10 00 00 00
10 00 00 00 DF 0C 00 00 C0 00 00 00 00 04 00 00 DC
20 00 00 00 00 01 EC 00 00 00 00 00 00 7D 10 C1 2A
30 00 00 00 00 60 00 00 00 00 00 00 00 11 01 00 00
40 7D 10 C1 2A 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 03 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 B4 02 00 20 85 00 00
80 10 29 00 00 01 4D 00 00 08 00 01 11 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
A0 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
B0 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0603
date 07/26/2010
DMI System Information
manufacturer System manufacturer
product System Product Name
version System Version
serial System Serial Number
UUID {73F9A660-FE8D-11D5-A861-002215D3690C}
DMI Baseboard
vendor ASUSTeK Computer INC.
model M2N68-AM
revision Rev X.0x
serial MF7088G05201548
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
clock speed 2200.0 MHz
FSB speed 200.0 MHz
multiplier 11.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 2048 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Port Connector
designation PS/2 Mouse (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation PS/2 Keyboard (internal)
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (internal)
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (internal)
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (internal)
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (internal)
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (internal)
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (internal)
designation USB7 (external)
port type USB
DMI Port Connector
designation USB8 (internal)
designation USB8 (external)
port type USB
DMI Port Connector
designation USB9 (internal)
designation USB9 (external)
port type USB
DMI Port Connector
designation USB10 (internal)
designation USB10 (external)
port type USB
DMI Port Connector
designation LPT Port (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation COM Port (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation Audio_Line_In (internal)
designation Audio_Line_In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio_Mic_In (internal)
designation Audio_Mic_In (external)
DMI Port Connector
designation Audio_Center/Sub (internal)
designation Audio_Center/Sub (external)
DMI Port Connector
designation LAN (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation D-Sub (internal)
designation D-Sub port (external)
DMI Port Connector
designation SPDIF_OUT (internal)
DMI Port Connector
designation CD (internal)
DMI Port Connector
designation PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation AAFP (internal)
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation PANEL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation CPU FAN (internal)
DMI Port Connector
designation SATA1 (internal)
DMI Port Connector
designation SATA2 (internal)
DMI Port Connector
designation SATA3 (internal)
DMI Port Connector
designation SATA4 (internal)
DMI Extension Slot
designation PCIEX16
type A5
populated yes
DMI Extension Slot
designation PCIEX1
type A5
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] 002215D3690C
string[1] To Be Filled By O.E.M.
string[2] To Be Filled By O.E.M.
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce 9600 GT
Revision A1
Codename G94
Technology 65 nm
Memory size 512 MB
Memory bus width 256 bits
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x107D)
Model ID 0x0622 (0x2AC1)
Performance Level 0
Core clock 650.0 MHz
Shader clock 1625.0 MHz
Memory clock 900.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600)
DirectX Version 11.0
ACPI
Reply to Cheerio_28
Best answer
sounds like your GeForce 9600 GT, is getting bottlenecked by your CPU. i would reccommend a CPU upgrade to a Phenom 955, since it is supported by your mobo:
http://www.cpu-upgrade.com/mb-ASUS/M2N68-AM.html
as seen above your mobo supports both c2 stepping and c3 stepping, and 125W version, you would need to update your bios though.
phenom 955: ($119)
http://www.newegg.com/Product/Prod [...] -_-Product
official AMD CPU support list:
http://uk.asus.com/Motherboards/AM [...] 68AM/#CPUS
BIOS upgrade:
http://uk.asus.com/Motherboards/AM [...] /#download
Message edited by ps3hacker12 on 05-22-2011 at 03:35:34 PM
------------------------------ HIGHEST OVERCLOCK RECORDED (9GHZ):
http://bit.ly/SvyUi
"Well, there may be a reason why they call them 'Mac' trucks! Windows machines will not be trucks."-MS CEO S. Ballmer
My Rig
Reply to ps3hacker12
okay thanks
just wondering if theres any temporary fixes as I need to generate the money
thanks!
Reply to Cheerio_28
you should try an anti-virus search though, it may be malware, since the 6000+ is still a great CPU, is your CPU usage going up to 90-100% during gaming or all the time, while doing normal things?
http://bit.ly/SvyUi
My Rig
Whilst doing both, its just much more noticeable when playing games because they become unplayable. Also which bios update do i select ? There seems to be 3 different 6000+ 's
I had formatted the computer on an occasion so I've ruled out malware.
Reply to Cheerio_28
is you windows 7 64 bit or 32 bit?
http://bit.ly/SvyUi
My Rig
try this:
then select windows 7 as os, then goto bios history, then global (DLM) the M2N68-AM 0603 BIOS the one at the very top.
http://bit.ly/SvyUi
My Rig
i was downloading to only realise i had the exact same zip and remembered i've already completed this a few weeks ago. The current version is 0603
Reply to Cheerio_28
ok cool, :P so now your PC is ready for whenever you decide on a CPU upgrade.
http://bit.ly/SvyUi
My Rig
Okay thanks a lot guys! :D
So is my current processor actually outdated ? Is the suggested CPU upgrade good for the long term ? thanks
Reply to Cheerio_28
Also, is my motherboard dated and fine to be running my 9600gt and the phenom 955 ?
Reply to Cheerio_28
yup, the Phenom 955, will last you another 2-4 years, and you can always overclock it in the future if you need the extra power. you should run a antivirus, also try putting a game on, then opening up task manager, is the CPU at 90-100% will the game is running? in which case im pretty sure your CPU is the bottleneck.
http://bit.ly/SvyUi
My Rig
There are 1901 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 5 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
