Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Toshiba SatPro 6100- where's my hi-speed USB?
Forum Laptops & Notebooks : General Laptops & Notebooks - Toshiba SatPro 6100- where's my hi-speed USB?
Archived from groups: comp.sys.laptops (More info?)
I have a Toshiba 6100, around 3 years old. It has 2 USB ports. Recently, I
started using a USB 2.0 flash drive, and whenever I plug it in, I get a
message saying I have plugged a hi-speed device into a non-hi speed USB
hub. I have found out how to switch off this warning, and I assume that it
just means stuff takes longer to transfer to and from the flash drive than
it would do if I had a hi-speed USB.
Can some kind person please explain:
1. Does this mean my 6100 never had a hi-speed USB hub?
2. Is transfer speed the only issue I should worry about? I use one USB
port for an external mouse, and the other to transfer files to and from the
flash drive.
3. What would be the value of adding hi-speed USB - and do I assume this
means I would need to get some kind of new hardware/card from Toshiba?
Benny
Sponsored Links
>flash drive.
1. The 6100 never had high speed USB ports
2. Transfer speed will be the problem--USB 2 is capable of 480mbps vs 12 mbps
3. Easiest way is to get a PC Card USB 2 adapter off of eBay. I use a Belkin
with no problems.
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0512-2, 03/26/2005
Tested on: 3/27/2005 5:40:42 AM
Reply to Anonymous
If you don't have USB 2 ports (and I don't think that you do), the only
way to add them is via a USB 2.0 PC Card, for probably about $20 to $40.
The only issue is transfer speed, but it's a big issue, USB 2 is FORTY
TIMES faster than USB 1.
> flash drive.
Reply to Anonymous
- 0 +
To Barry and sded- thank you for the info- got a USB 2.0 PCMCIA CardBus at
the local computer shop, and the data transfer really rips!
Benny
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:4246F5B3.3090900@neo.rr.com...
I
it
than
the
> > flash drive.
this
Reply to Benny
There are 633 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
