Hi all,
I've almost done assembling a new system (my first) and I'm left with the control type of fans dilema.
my MB supports PWM and can work with EasyTune6.
The thing is, I really would like to have a physical control over the fans as backup (not via a software but by knobs) should the automatic control fail (in TC the temperature sensor will "ware out" and in PWM maybe a bug or a virus...)
I wish someone could help me out with the following questions (or just with one), I'm really stuck with this:
1. Is it possible to have this sort of combined control over fans?
2. reffering to the CPU fan specificlly- is this fan always on and always on full speed (no control)? Or is it controlled seperatably than the case fans because of its importance?
I sortta understood that PWM means that when the CPU "feels" load it signals the case fans to start working, but what controls the CPU fan itself?
3. Does PWM control signal to all fans to work at once (noisy and not economic) , or it can signal a single fan?
4. I think TC's advantage over PWM is that each fan is controlled indepandently (has its own sensor that triggers it on), which is less noisy, more economic, and should one fan fail, the others kick in as backup. What do you think?
a lot of thanks in advance
