Will this graphics card work on my system??
can anyone tell me if this graphics card will work well on my system??,im am not planning to overclock my cpu or graphics card,thanks in advance
http://www.gigabyte.com/products/product-page.aspx?pid=...
Gigabyte GA-EP45-UD3L, Intel P45/LGA775/ATX ;NZXT APPOLLO CASE
4GB KIT(2x XMS2 2GB) Corsair 'XMS2' [TWIN2X4096-6400C5], DDR2/PC6400/800MHz
550W Greatwall power supply
500GB Seagate ‘Barracuda’ [ST3500418AS], 7200.12/SATA/16MB CACHE
Intel® Core™2 Duo E7600, 3.06GHz/FSB1066MHz/3MB Cache/LGA775
XFX HD 4770 512MB 128Bit, [11X-HD4770-512], PCIe
Related ressources
dalta centauri said:
How long have you had the 4770 running?
Most likely if it's been running without any problems with a 4770 then the 450 should run fine as well.
i have had the 4770 for approx 12 months,im thinking the 5770 1gig card is also a good option..thanks
Ask the community
