Need advice on 2600k gaming system
I know the chip got recalled, so waiting on the motherboard, however i heard the flaw was in ONE of the sata port, does that mean i can actaully buy one of these flawed mobo if i dont use that port?
anyway theres what im going to buy, please give some advice thank you
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
EVGA 015-P3-1583-AR GeForce GTX 580 (Fermi) Black Ops Edition 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130589
CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145325
OCZ RevoDrive OCZSSDPX-1RVD0120 PCI-E x4 120GB PCI Express MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227578
Acer GD235HZbid Black/orange 23.6" 2ms(GTG) HDMI Widescreen 1080p 120Hz
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009222
I'm still not sure if thats the ram i should get as i dunno if it will be compatible, also what power supply and theres no mobo for LGA1155 on newegg yet.
8 answers Last reply
More about need advice 2600k gaming system
  1. DDR3-2000 has little value in a SB system since you are not raising BCLK's. Invest that money in low CAS latency at DDR3-1600
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226178
    With the 580, I'd get
    MoBo - $260 - ASUS P8P67 WS Revolution as it can run both cards at x16 x16. Without the Nf200 chipset that this MoBo comes w/ all other boards run at x8 x8
    Case / PSU:
    Option 1:
    Case - $140 - Antec DF-85 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129087
    PSU - $150 - Antec CP-1000 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371043
    Option 2:
    Case - $200 CM HAF-X http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
    PSU - $215 - Corsair HX1000 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
    I'd hold off on the SSD's .... proverbial poop hit fan on OCZ today (See THG home page) and the next gen may already be arriving by the time SB resurfaces.
  2. I wouldn't get that RAM. 2000 mhz sticks are just an unnecessary expense. Instead, I'd pick up either these G.Skill Ripjaws 2x4 GB 1600 mhz CAS Latency 7 for $150 or these G.Skill Ripjaws 2x4 GB 1600 mhz CL 9 for $100. I don't think CL 7 is worth $50 over CL 9, but maybe you do.
    I'd also swap the SSD for a SATA device, like this OCZ Agiilty 2 120 GB for $190 after rebate or G.Skill Phoenix Pro 120 GB for $240.
    As for a board, there were ones earlier. My two favorites were the ASRock P67 Extreme4 ($150ish) and Asus P8P67 Pro ($190ish). Whenever new versions of those are released, those would be what I looked at first.
    As for PSUs, I'd go with a high quality 850W. I like either the XFX 850W for $126 (with shipping and rebate) and the SeaSonic 850W for $125.
  3. If you can find one of the flawed MBs, yes you can use it just fine if you connect your HDD and optical drive to the 6G ports, which are backward compatible with 3G devices. But at this time you might as well wait for the new revisions...
  4. thank you all for the replies, i will get the ddr3 1600 ram instead of 2000, also i dont think i will be doing SLI because its expensive and i'm always under the impression that it will only give about 30% more performance increase.
    the XFX 850W seems good, i just dont know how much watt will i really need.
  5. You'd want at least 850W for SLI. You definitely wouldn't need the 1000W that Jack's recommending. If you're 100% sure you never want to try SLI, you could drop that to a 650W model. Check out Antec, SeaSonic, Corsair, Silverstone and XFX's choices at that wattage.
    I would suggest that you consider keeping the option to SLI open. You don't end up spending that much more for the opportunity, usually about $20-30 on the board to get a second PCIe 2.0 slot at 8x and maybe $20-30 on a larger PSU. SLI generally improves performance by 60-75%, depending on the game and the drivers. It's not something you'd want to start a build with, but it's a great option later on in the build's life.
    Look at it this way. In 3-4 years, when a single GTX 580 is beginning to show it's age, your two options for upgrading performance are to either buy a brand new card or add a second 580. A new card will likely run another $500+, and might give you 50% added performance, but come with new features (new DirectX versions), which aren't likely to be standard yet. Or you could buy a second GTX 580, likely for around $250, and get 60-75% more performance, but you wouldn't have those new features. The second 580 would likely tack on another 2-3 years of life to the build, at which point you'd have to replace the entire machine. You'd also get another 2-3 years with the new single card, which you could carry over to a new build for a short while, if you wanted to get similar performance out of your new machine.
    @Jack: Why do you always recommend the ridiculously overpriced HAF X? It's $200, and you don't get anything useful for it over the $120 HAF 932 or $90-100(ish) HAF 922. The only added features the HAF X has is an added two expansion slots (which you will NEVER need), one LESS 3.5 bay, one more 5.25 bay (over the 922 only), two slighly bigger fans (230 mm vs 200 mm) and one more fan (than the 922). The X isn't even that much bigger. It's 23.2 x 9.1 x 21.7, while the 932 is 22.70 x 9 x 21.50 and the 922 is 22.20 x 10 x 19.7. That's really not a lot of useful space. It's a horrible deal.
    Here is a list of sub $200 cases that are all better choices than the HAF X: Silverstone Raven RV02-BW, Coolermaster's Cosmos S, Antec Lanboy Air (massive cooling), and Antec 1200 V3. Those are only the overly expesnive ones, and only considers performance. If you considered how much better they look, all four of those would be a steal compared to the HAF X. If you included price, I'd have to throw in the Antec 900, HAF 932, HAF 922, any Lian LI and Coolermaster's 690 II. They are generally smaller, but they're much more attractively priced. Any of the first group would fit the needs of someone who would actually need something like the HAF X, while the second group would fit the needs of any gamer.
    As for spending $70 to get 16x/16x, that's also a horrible idea. The performance difference between 16x/16x and 8x/8x is only 3-4% at the most. Tom's did an exhaustive review of it a long time ago. They also found that the only card that it would actually make a material difference for is the HD 5970 is Crossfire. The GTX 580 is a lot less of a card, so it would matter less. And just to point out, that 3-4% really only equates to 1-2 FPS. That's definitely not worth $70.
  6. True, also why swap the ssd for a sata one?
  7. Mainly because they're more mainstream and quite a bit cheaper.
  8. thank you all again, what you guys think about the incoming GTX590? personally i take nvidia over ati anyday, but i heard gtx590 will be 100$ more expensive and the cores are downclocked, so they are slower than 6990?
Prebuilt Systems Product
