HI there,
I was wondering to buy a graphic card for my new computer. I have:
Intel Core I3 540 3.07, 3.06 (2 Core) and 4 threads. 4GB DDR3 1333 ram, 1TB Hard drive.
I will be using for Gaming, so please recommend me the best graphic card. If you know another graphic card please do tell me.
My budge it around £70, anything between.
I have looked at few graphic card, but no sure which I should I buy. Here is the detail and link.
VTX HD 5570 1GB DDR3
* Product Description VTX3D Radeon HD5570 1GB DDR3 128Bit
* Interface Type PCI-E
* Chipset Radeon HD 5570
* Memory size 1024MB
* Core Clock Speed 650Mhz
* Memory Clock Speed 800Mhz
* Stream Processors 200
* DX Supported DX11
* Display VGA / HDMI / DVI
* Hyper Memory Support Yes, 2GB max Vista/Win7 only
* Cooling Fan
* PSU Requirements 400Watt
* Multi Card Support Yes
http://cgi.ebay.co.uk/VTX-HD-5570-1GB-DDR3-Graphics-Video-Card-DVI-HDMI-/360312207916?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item53e447fa2c
Sapphire HD 5450 1GB DDR3
* Model Number:11166-02-20R
* Package Type:Retail
* Warranty:2 Years
* Chipset:ATI Radeon HD 5450
* InterfaceCI Express 2.1
* Video Memory:1GB
* Memory TypeDR3
* Engine Clock:650MHz
* Memory Clock:1600MHz (800MHz DDR3)
* Memory Interface:64-bit
* Stream Processing Units:80
* RAMDACs:400MHz
* Max. Resolution:2560x1600
* Connectors:VGA‚HDMI‚DVI-I
* DirectX Support:11.0
* OpenGL Support:3.2
* Compatible OS:Windows XP‚Windows Vista‚Windows 7
* Gross Weight (Kg):0.34Kg
* Special Features:ATI Stream technology‚40nm Process Technology‚Enhanced Anisotropic Filtering‚Accelerated Video Transcoding‚Display Flexibility‚Dolby TrueHD and DTSHD Master AudioTM Support‚ATI PowerPlay Technology‚ATI CrossFireX multi-GPU technology
* Package Contents:Quick Installation Guide‚Driver CD
http://cgi.ebay.co.uk/Sapphire-HD-5450-1GB-DDR3-Graphics-Card-DVI-HDMI-/360319946962?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item53e4be10d2#shId
Asus ATI Radeon HD 5450 1024MB GDDR3
Graphics Engine ATI Radeon HD 5450
Bus Standard PCI Express 2.1
Video Memory DDR3 1G
Effective Memory Size 1024 MB
Engine Clock 650 MHz
Memory Clock 800 MHz ( 400 MHz DDR3 )
Memory Interface 64-bit
CRT Max Resolution 2048 x 1536
DVI Max Resolution 2560 x 1600
D-Sub Output Yes x 1
DVI Output Yes x 1 (DVI-I)
HDMI Output Yes x 1
HDCP Support Yes
Software Bundled ASUS Utilities & Driver
Low Profile Bracket Bundled Yes ( 2 slots )
http://cgi.ebay.co.uk/Asus-ATI-Radeon-HD-5450-1024MB-DDR3-PCI-E-Graphics-Card-/130381714098?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item1e5b5b12b2
Thank you for your time.
* DX Supported DX11
* Cooling Fan
* Warranty:2 Years
* Video Memory:1GB
* Memory TypeDR3
* RAMDACs:400MHz
HDMI Output Yes x 1
HDCP Support Yes
