Upgrading power supply suggestions
sacer
12
Hi all, I'm looking to upgrade my power supply from my measly 300w to support a better graphics card.
I'm running a HP Verde SE a6645f PC with the following specs:
http://www.hp.com/large/campaigns/ [...] asheet.pdf
Vista 64bit
AMD Athlon X2 4850e 2.50 GHz dual-core processor
Expansion slots:
1 PCI (one available)
2 PCI Express x1 (two available)
1 PCI Express x16 (one available)
Monitor: 1920 x 1080
Motherboard: Asus M2N68-LA (Narra3)
microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
What would be a good 500w that my motherboard can support?
On the upside, your PCI-E 16x slot isnt at the very top edge of the board like many are so you can fit a dual slot card in, but it will need to be fairly short.
What graphics card are you looking to install and whats your overall budget for the upgrade? That determines what PSU you need, but your motherboard wont be an issue, its an ASUS board so it will take normal power supply connectors.
For reference for others:
sacer
12
Mostly WOW. Thinking of getting the HD5670
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102870&cm_re=5670-_-14-102-870-_-Product
Are there any cheaper PSUs that I will suffice? People are telling me I don't even need to upgrade from my 300-watt 100 - 240V, 5A, 50/60Hz PSU but I'd rather not risk blowing up my comp
sacer
12
My budget is 130-150 for GPU & PSU
Latest posts
