Is my power supply enough for this GPU
Hello...again,
Parts:
500w ocz psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341038&cm_re=ocz_power_supply-_-17-341-038-_-Product
MSI Twin Froz GTX 460
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127519&cm_re=gtx-_-14-127-519-_-Product
MSI GTS 450
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127527&cm_re=msi_450_gts-_-14-127-527-_-Product
Phenom II X2
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846&cm_re=phenom_ii-_-19-103-846-_-Product
Y-Connector
http://www.newegg.com/Product/Product.aspx?Item=N82E16812198018&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Its pretty much covered in the title, but if I get the msi gtx 460 above will my power supply be able to support it if my processor is a that phenom ii x2 3.2ghz also?
Also, I noticed that the 460 required 2 6pins (but i read http://www.tomshardware.com/forum/303000-33-tomshardware and it said it a y-connector helped their problem) and my psu only has 1 6pin pcie connector, if i use that cable, will the 460 work?
1 answer Last reply
More about power supply
  1. The GTX 460 should come with adapters from the Molex 4pin to GPU 6pin plugs.
    I think that PSU should be able to handle it, though OCZ's PSU really are hit-or-miss in many cases. I'd recommend a solid Antec like my EA650, which can handle much more than just a single 460.
Homebuilt Power Supplies Systems Product MSI-Microstar
