Can't get wireless PCI card to work
My motherboard is the Zotac G31 Value, with which I've had absolutely no problems so far (and have had it for about a year now), and I'm running 64-bit Windows 7.
However, I can't seem to get a wireless PCI card to work.
The first one I tried was an older one, the Level One WNC-0500. My device manager knew it was there, and even automatically installed some RALink drivers. But the device manager also displayed a yellow exclamation point next to it, and the software that was installed to use the card said that the card was not there.
So I bought a newer one, the Zonet ZEW1642s, which says that it's Windows 7 compatible, and reviews on Newegg said that others were able to simply plug it in and use it. But I'm having the same problem as before - device manager knows it's there, but displays a yellow exclamation point, and the RALink software cannot detect the card.
Does anyone know why else this could be? Someone pointed out that the card I have is only compatible with a PCI 2.x slot, not the older 1.x ones - but the instruction manual for my mobo says that it is PCI 2.1 compliant.
Thanks in advance for any suggestions anyone has!
4 answers Last reply
More about wireless card work
  1. I've never used or have any experience with wireless PCI cards. But it doesn't seem like it'd be a plug-in-play type of thing. Sure there's no drivers to install?
    http://www.zonetusa.com/products-57.aspx
    Driver/Utility Download on this page.
  2. I would suggest running the latest Intel INF file, which has all the latest mobo drivers. All my windows 7 wifi cards or USB sticks have been plug and play with no problems.
    There are drivers, but Windows tried to install them automatically. When that didn't work, I used the disc that was included with the card. That still didn't work, so I downloaded them from the website like you suggested, still not working. Thanks for the suggestion though!
    I tried this...it told me my INF was out of date, so I updated it. Still no luck with the wireless card though :\ Thanks anyway for the tip!
    The Zonet ZEW1642s was also sold as the Edimax EW7727In and compatible with XP, Vista and Windows 7. Here is the link
    http://www.edimax.com/au/support_detail.php?pl1_idSelect=support.php%3Fpl1_id%3D1%26mwsp%3D0&pl1_id=1&pd_id=257&button=Go#01
Wireless Device Manager PCI Components
