WHEN I CONNECT THE 4 PIN 12 NOT GETING ANY POWER ON MY 945gcm-s
Last response: in Components
Power supply Expert
Asrock 945GCM-S
24pin main power below memory sockets
4pin aux power behinf back panel usb ports.
If you have this setup correctly and you have connected the case cables to the correct pinso n the motherboard, have you tried just shorting the 2 power on pins to rule out a bad case cable.
Ask the community
