I built my computer a little over a year ago:
AMD 955 BE (Stock Cooler), on a Gigbyte MB, OCZ 600 watt power supply, Radeon HD 5770 Graphics card, 8MB of G Skill inside a Antec Three Hundred Illusion - There are a lot of fans blowing - Three with the case, power supply, graphics card, and CPU makes six fans.
Recently the CPU core temp has been running warm - 50-60 degrees Celsius - recommended max is 62. This up from the 40-50 range a few months ago. So I bought a XIGMATEK Gaia SD1283 http://www.newegg.com/Product/Product.aspx?Item=N82E16835233082 - Good reviews, good price, and I could also then overclock my CPU. So far so good.
Then I read that this heat sink supports proper cross flow installation on AMD Mother Boards. So my question is - WHAT is proper cross flow? And what do I need to do to install this correctly?
Many Many Thanks!
Many Many Thanks!
