I just built my new PC which has two WD hard drives - a 500 Gb Green SATA 3Gb/s and a 1 Tb Black SATA, 6Gb/s. The smaller one is to serve as a backup drive.
When I try to select the backup drive in Win7's backup it doesn't show up, which I found out was because it was an active drive. If I make it not active, it shows up but can't be selected because it is also a system drive (and my system won't boot). Come to find out, when Win7 installed, it didn't make the 1Tb drive a system drive.
So my system files are on the backup drive and not the boot drive.
Is there a way to:
1) remove the system files from the backup drive and
2) put system files on the boot drive
without reformatting either drive?
Is there a way to:
