Solved
Help with Non Overclocked Build
Hi Guys,
I'm trying to put together a decent non-overclocked build and stay at a reasonable price point. I haven't built a computer in many years so any suggestions would be very greatly appreciated. Here's what I am thinking so far.
Approximate Purchase Date: This week
Budget Range: 600-800 after rebates
System Usage from Most to Least Important: Gaming, surfing, perhaps some web design and photo editing
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: Best price/performance
Overclocking: no
SLI or Crossfire: No
Case: NZXT Gamma
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
Mobo: ASRock 890 FX Deluxe4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157208
CPU: Phenom II X4 955 Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
GPU: XFX Radeon HD 5670 512MB
http://www.newegg.com/Product/Product.aspx?item=N82E16814150504
or?
Saphire Radeon HD 5770 1GB at +$20
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102898
PSU: Corsair Builder Series 500W
http://www.newegg.com/Product/Product.aspx?item=N82E16817139018
RAM: Crucial 4GB DDR3 1066
http://www.newegg.com/Product/Product.aspx?item=N82E16820148150
HD: WD Caviar Blue 500GB 7200RPM
http://www.newegg.com/Product/Product.aspx?item=N82E16822136073
Windows 7 home premium
Like I said it has been a long time and in truth I am pretty ignorant to hardware needs and compatibility at this point so is there anywhere I am just wasting money here or could get better products for less? This build comes out to about $730 right now.
Thank you,
Bodie
19 answers Last reply Best Answer
More about help overclocked build
  1. Ok thanks, looks much better this way
  2. Best answer
    Resolution?
    Just from looking at it a few changes.
    Motherboard: Asrock Extreme3 770 75$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157195
    That motherboard is good enough for you, you don't OC and you don't CF. But you'll have the future proof of SATA III and USB 3.
    Power supply: Antec Neo Eco 520w 40$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030&Tpk=neo%20eco%20520
    Better PSU, lower price. Good efficiency.
    Memory: Not a big issue, but this is just 2$ more and better. Solid brand too. DDR3 1333, instead of 1066. Not that it matters a bunch.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218
    HDD: Seagate Barracuda 7200.12 500gb 40$
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395&cm_re=500gb-_-22-148-395-_-Product
    Faster and same price. The .12 is a great revision actually, most cases as good as the F3.
  3. Thank you for the suggestions I like all of them except on the Barracuda it looks like a lot of people have been getting bad drives lately on the newegg reviews. Also as far as resolution I'm not sure I will most likely be using an older 17in CRT which handles fairly high resolution but might also go to my new plasma 1080p TV sometimes. From what I've been reading it seems like I should be spending a bit more on a GPU what is a good pairing with the Phenom II X4 955?
  4. If you use your plasma you probably want something like a 6850 or 460 1GB. Those two would be more than enough for your CRT monitor. If you use your TV alot, you should check out this combo. 6870+955.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.609153
    A 5770, 6850 or 460 1GB would be good enough for your CRT monitor, even the 460 768mb. The 6870 might be overkill for it, but it would be recommended for your 1080P TV.
    I hate those who scorn at the 768mb version of the 460. It saves people $50 compared to the 1gb.. which is significant when the cards are $110 (768mb) and $160 (1gb)..
    Honestly, theres no visible difference in fps (upto 5% difference) which can't warrant an upgrade in the graphics settings nor increase the fps by any distinguishable amount.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814162058&cm_re=gtx_460_768mb-_-14-162-058-_-Product
    $108 AR. Same price as the 5770 and it literally blows i/t out of the F***ing water :)
    Furthermore anoboshi, the $42 ram you quoted, xms3 by corsair with 1333MHZ is beaten by this $40 xms3 ram by corsair with 1600MHZ. Free, $2 less upgrade..
    However, this kingston ram takes the cake, $50 and only $25 After mail in rebates, and with a $5 promo code. $20 for 1600MHZ kingston ram.
    BUY NOW!
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820104203
    $5 off w/ promo code EMCKHHH42, ends 2/28
  6. That's a good deal vibhas. Just be sure to note that my name isn't "anoboshi". Also what corsair ram are you talking about that is 40$? There is no kit below that kit I listed from Corsair that is 40$ for 4gb (2x2gb).
    I don't scorn the 768mb.
    Lowest price 460 768mb: 147$
    Lowest price 460 1gb: 160$
    Where is the 50$? Your talking about?
    Even after rebate.
    Lowest price 460 768mb AR: 110$
    Lowest price 460 1gb AR: 140$
    Even after rebate.
    Here is the $40 ram (AR) http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
    Sorry bout the name, i read a book and misplaced your name.
    Cheapest 768: $108
    But i can't find any 1GB 460 on newegg for $140.
    The cheapest i found is $150 'open box' and $155 'rectified' and those aren't fair. So its your turn to post the link for the 1gb version of the 460.
    But it doesn't really matter - Whether $30, 40 or 50 or 100 more the 768mb version is clearly superior in terms of price/performance. For the additional 20-50% cost you get 4% more performance @ 1080P so.......
    As opposed to a 130~% (Additional card, higher rated PSU etc etc) additional cost for 85% more (SLI)
  8. Best answer selected by BodieRyan.
  9. .12 Seagate keeps up with Samsung F3? I didn't know that...I'll have to look up some benchmarks. After the .11 firmware debacle, I just figured to stay clear of Seagates for a year or two.
  10. This topic is done. But for your info. Check prices better please?
    160$ as I said before rebate. 140$ AR.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814261088&cm_re=460_1gb-_-14-261-088-_-Product
    7200.12 1TB review: http://www.bit-tech.net/hardware/storage/2009/04/13/seagate-1tb-7200-12-review/3
    Idk why that says F1 1tb, Well as you can see not the same HDD. But I guess fairly close. That's what most HDDs are as of late.
    Aznshinobi that's not right mate.
    That's a low blow... the 1GB SE model which is clearly worse than any other 460 model - The 768mb version AND the normal 1GB version easily outclass it. That 460SE is close to the 450GTS model in performance.
    I did indeed check prices well - Anyone can tell you the 460SE is a bad terrible version of the card, especially given its price point. The $50 difference + stands (Actually $60+ if not 67~) as the 460SE is basically a different card almost!
  12. How I didn't notice that it says SE
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814500169&cm_re=460_1gb-_-14-500-169-_-Product
    I guess the cheapest 460 1gb is 160 AR. O well, I still would get the 6850 anyway. More of an AMD fan. Not a huge one, but still like em more than Nvidia.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161348&cm_re=6850-_-14-161-348-_-Product
    150$ AR. Not WAY better than the 460's but still better. Even better in dual card.
  13. The Samsung Spinpoint F3 1TB has two 500GB platters. It outperforms the F1 by a good margin and matches the $80 Caviar Black 1TB drives. It is faster that the 7200.12 in every test: http://www.bit-tech.net/hardware/storage/2009/10/06/samsung-spinpoint-f3-1tb-review/
  14. ^ I do realize the 2 platters the F3 has, but I didn't realize they made a F1.
  15. Yeah, it was the last version from 2008 that got outperformed by the newer drives. I did a good deal of research into the Samsung Spinpoint F3 1TB drives before I bought 3 for RAID 5 last August. It was $58 on Newegg--so I bought 3. I'd been planning on a single 2TB drive, but they were going for $130 at that point.
    Now my short stroked 300GB RAID 0 with RAID 5 on the remaining space screams--425MB/s on HDTach across the entire 300GB and over 2GB/s Burst speed!
  16. ^ Yeah, I was thinking about doing a RAID 0 setup for F3's (or "F5" [just making up a series] for the SATA III revision of the F3's). But I thought about it, and I just decided that if I do that, might as well do a 60gb SSD boot and just a 1TB for the rest of the stuff :P Even with those awesome benches, RAID 0 HDDs still don't boot as fast as a single SSD.
  17. Hmmm...close. I haven't timed my bootup, but I lose 4 seconds initializing the RAID array. I get 425MB/s in HDTach on my 300GB (3x100GB) RAID 0 with the F3's.
    SATA III is pretty pointless with conventional HDDs. I guess WD Caviar Blacks do it just because they can sell a couple extra to people thinking it's better?
  18. ^ I see many people buy WD Blacks purely off the name "Western Digital" When they are getting ripped about 20-30$ in most cases. (The base being the Samsung F3's)
Homebuilt Build Systems Product
