Need Gaming Build Help
Hello everyone, I'm helping a friend build a gaming computer. What do you think so far and do you have any ATX motherboard recommendations? (needs USB 3.0, SATA II, and ability to possibly SLI two 580's later on as well as an open slot for a wireless card )
AMD Phenom II X6 1100T Thuban 3.3GHz
GeForce GTX 580
Western Digital Caviar Black 500GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
(why does the SATA 3.0GB/s version of this have over 1,000 reviews and this has 24? is it just newer?)
NZXT Phantom
COOLER MASTER Silent Pro Gold Series ATX SLI Ready CrossFire Ready 80 PLUS GOLD Certified
3 answers Last reply
More about need gaming build help
  1. I wouldn't be building an AMD based build if one can afford twin 580's. New SB MoBos should be here in 1-3 weeks.
    This is just under $1800
    Case - $160 - Antec DF-85
    Case Fans - $15 - Antec Red 120 mm
    PSU - $150 - Antec CP-1000
    MoBo - $395 - ASUS P8P67 Pro
    CPU - incl above - Intel Core i5-2500K
    Cooler - $40 - Scythe SCMG 2100
    TIM - $5 - Shin Etsu
    RAM - $155 - (2 x 4GB) Mushkin CAS 7
    GFX - $370 - EVGA GTX 580
    GFX - Later - Same
    HD - $65 - Spinpoint F3
    SSD - $245 - Crucial C300 2.5" 128GB
    Card Reader $35 AFT XM-35U
    DVD Writer - $22 - Asus 24X DRW-24B3L w/ LS
    OS - $140 - Win 7-64 Pro OEM
    Another Case / PSU option would be
    HAF-X ($190) w/ Corsair HX-1000 ($215)
    Reason 1TB gets so many reviews is price per GB for 500GB model makes in unattractive in comparison. You don't need SATA III (6GB/s) .... transfers from cache will benefit from the SATA III interface but the mehanical drive can't approach 1/2 of SATA III speeds.
    Above 580 is clocked slightly faster than the EVGA model
  2. One of the 500 GBs was going to be a backup, also I don't think he needs a SSD or Card Reader. Also, I was going with AMD since it isn't like he will do anything super processor intensive so I didn't see the point of going with Intel
Homebuilt Gaming Build Systems Product
