HDMI to VGA cable to hookup monitor to PC ?
- Possible to adapt a vga monitor cable to go into an hdmi port on pc? Forum
- SolvedConnecting monitor to desktop using vga to hdmi cable Forum
- SolvedHi I was wondering if I should use a VGA or hdmi cable.. Monitor is an ASUS VX228H and I'm connecting it to a Dell M14x lapto Forum
- SolvedVGA cable with HDMI/DVI monitor ? Forum
- SolvedPC has DVI/HDMI - My HDTV only has vga/hdmi hook-ups, hdmi looks bad - Solutions? Forum
- Can I connect my laptop to a monitor using a vga-hdmi cable, using NVIDIA GeForce 820m? Forum
- I have a laptop that I am trying to add an HDTV with a HDMI cable and a monitor that is VGA. My laptop has one of each ports. Forum
- SolvedCan I connect my old PC to new Sony Bravia TV (KDL-50W685A) using VGA to HDMI cable Forum
- SolvedConnecting a HDMI and VGA cable to my Pc Forum
- I have the new x box 360 and it only has a hdmi port, how do I hook it up to a vga port monitor? In other words what cable wou Forum
- I want to connect my xbox 360 by a hdmi to vga cable to my led monitor.But my monitor shows no signal check ur connection Forum
- SolvedNon-crisp display on my PC monitor when connected to laptop through VGA cable Forum
- SolvedI've tried running my PS3 through the HDMI cable to a DVI adaptor in order to connect to my pc monitor but all I'm getting is, Forum
- Can i use vga to hdmi cable to connect ps2 to monitor Forum
- SolvedDo I need a cable to make my monitor speakers work on VGA PC? Forum
- I need to connect an HDMI pc to a VGA TV, not the other way round. I have a cable HDMI to VGA, but get no signal on the TV. Wh Forum
- SolvedRunning an Xbox360 through a PC monitor and PC speakers, HDMI to VGA Adapter....possible?.... Forum
- My screen is cracked and I had a VGA hookup now the tv doesn't recognize for whatever reason so I hooked it up thru hdmi but n Forum
- HDMI cable with PC gives bad quality. VGA is perfect. Forum
- Problem w/ my Acer monitor hookup to Dell laptop with VGA cord, plz help! Forum
- More resources
