Archived from groups: comp.sys.laptops (More info?)
Hello,
I am seeking help on a problem I'm having when connecting my Dell
Inspiron 9300 laptop to my stereo amplifier, a NAD C340.
I went the cheap and simple route, buying a cable that hooks into my
laptop's headphone port, with 2 RCA outputs that I connected to the
"auxillary" input on my stereo receiver. When I do this, I get a lot
of buzzing, and can barely hear anything playing on my computer. This
happens even when all volume levels are turned up to the max. This
confuses me because when I use this cable to hook up my mp3 player and
walkman, the music plays through my stereo loudly and clearly.
Can anyone tell me why I am able to get good sound results with my mp3,
walkman, etc, but NOT through my laptop?
I would really appreciate any advice that anyone could give.
dylandavis@gmail.com wrote:
> Hello,
What happens when you disconnect ALL other cables from the laptop,
INCLUDING the AC adpater?
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 13" LCD for Mitac 6133 Samsung HT13X13-201
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
I still get buzzing when I disconnect all cables and run on battery
power, and I don't get a buzz when I listen to the headphones.
I think that I have overestimated the severity of the buzz in my post -
it is not that loud, and I think that it is just distortion from
turning up the volume very high, which I have to do in order to hear
any sound at all from the stereo when my laptop is connected. I'm
pretty sure that it is not a grounding issue, etc. The buzz is not
bad.
The real problem is the fact that, even when my laptop volume and the
stereo volume are turned to the max, I can barely hear my music. And,
as I stated before, I have no trouble when I hook up my mp3 player or
walkman to my home stereo.
Incidentally, when I plug regular headphones in to my laptop, it sounds
great. Is this just a big mystery?
Thanks for the responses so far. It's great to see people helping
others! Any other input is still greatly appreciated.
> - it is not that loud, and I think that it is just distortion from
> bad.
> sounds great. Is this just a big mystery?
It's suprising (and I'm a little baffled) that there is an S-video
output but no complementary audio output except the headphone port. I'm
wondering if you go into the sounds control panel and change the speaker
option you might be able to improve the output signal?. Is there a
separate audio card control panel with adjustable power output level?
You have checked that the microphone input is muted? Are you using the
correct line-in on the amplifier? You might try a higher quality AR or
Monster cable as a last resort - I know that AR audio cables are a big
improvement over the typical thin generic audio cables that come
standard with A/V equipment. Have you tried connecting the audio to
your television to hear what happens there?
Quaoar-
You have given me many great suggestions. I, too, find it ridiculous
that my computer has an S-video output, but the headphones port is the
ONLY audio output. No seperate line out, etc.
Anyway, great suggestions. I will try them all and report back. Many
thanks!
post
hear
> > bad.
the
And,
or
I'm
speaker
the
or
big
> Q
Hi,
Sounds like the problem I have connecting my turn table to my stereo - in order to hear it properly, I have to run it through a pre-amp. Why you'd need to do this with a notebook is puzzling, though.
Just my two bits.
MP
bad.
> No, in fact it sounds great when I just plug my headphones in to my
> laptop. That's why I'm so baffled!
Are you certain the audio cable you're using is a stereo cable? E.g., three
conductors on the mini-phone plug?
Are you certain that it's fully inserted? Some need to be pushed in until
they "click". Also, the laptop's internal speakers will usually turn off
when the plug is correctly inserted.
Another "Are you certain..."
Are you certain you're using the correct amplifier input?
Different inputs, *way* different results (i.e., impedance matching).
On 3/30/2005 10:05 AM, dylandavis@gmail.com wrote:
> Hello,
Did try adjusting the headphone volume from Windows? Another option is
to get a SqueezeBox to connect to your stereo and install slim server on
your laptop to stream music to it wirelessly.
dylandavis@gmail.com wrote in message news:<1112198720.246720.197100@l41g2000cwc.googlegroups.com>...
> Hello,
Are you sure that the headphone jack plug is EXACTLY the same shape as
the plug on the cable to the stereo unit. Sometimes the tip of the
plug is slightly different and it makes poor contact. I use an
extension lead (male headphone jackplug on one end and female
headphone jackplug socket on the other) with the same type of cable
you are trying to use. I sometimes get buzzing if the junction
between the two cables isn't perfect. Try rotating the plug - does it
help?
RichardHenshall@utvinternet.com (Richard Henshall) wrote in message news:<4f52affd.0504060535.26b4746c@posting.google.com>...
> > Hello,
> help?
> rgds
> Richard
An interesting discovery for me was that I experienced exactly this
original problem at the weekend, using a different PSU for the laptop.
The one that gave the buzzing had a three prong cloverleaf
(mickey-mouse) mains connector, where the quiet one had a two prong
(figure-of-eight) mains connector.
>>>Hello,
>>help?
>>rgds
>>Richard
> Could this be the explanation - an earth loop?
> rgds
> Richard
yes,
mike
Wanted 12" LCD for Compaq Armada 7770MT.
