I doubt it.
Personally i find no benefit from side intake fans.
Have 3 towers with side panel fan mounts and don't use them.
Tried them and noticed no temp benefit only extra dust infiltration.
Your better off buying a good cooler like the Mugen 2 which will yield far more temp benefits then a side fan ever will.
The Phantom comes with 2x120mm lower side panel fans anyways.
Lose the 200mm fan option.
