Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Salvaging old parts for HTPC. Need advice!
Forum Systems : Homebuilt Salvaging old parts for HTPC. Need advice!
Hi all,
I have never built PCs before, so I am a bit of a n00b(please bear with me). I have a 2 year old HP Pavillion a6535c desktop. I want to salvage a few old parts from this computer but I need some good advice. This will be strictly a HTPC, primarily used for media(Bluray, MKV, DVD, AVI), and possibly TV.
Here is some background information:
Country: Canada
Approximate Purchase Date:Until May 2011
Budget/Parts Preferences: Economic but open to opinions.
System Usage: HTPC. Strictly for media(Bluray, MKV, DVD, AVI), and possibly TV.
Preferred Websites: Anything as long as its Canadian. I.E. newegg.ca, ncix.com, and etc
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: I have a 32 Inch Sony Bravia. HDMI. 720p ?
Parts that I have:
Processor: Intel Core 2 Quad Q6600 @ 2.40 GHz (Socket 775 LGA)
Motherboard: This is the confusing part for me. When I run CPU-Z it says (Manufacturer: Pegatron Corp; Model: Benicia; Chipset P35/G33/G31)
But the manufacterer website says: Asus IPIBL-LB and Benicia-GL8E with form factor: Micro-ATX: 24.5 cm (9.6 inches) x 24.5 cm (9.6 inches)
Here is the website: http://h20000.www2.hp.com/bizsuppo [...] =c01324212
RAM: 6GB DDR2 (Dual Channel)
Video Card: NVIDIA GeForce 9500 GS (512 MB)
OS: Windows Vista Home Premium 64 bit
HDD: 500GB SATA 7200 RPM 3.0 Gb/sec
PSU: 300W
Parts I would like:
- Bluray COMBO drive
- Do I need a new mobo and PSU ?
- Small casing
- Remote (IR receiver)
- Possibly a tv tuner that I can hook up to my PVR.
- Can you suggest a good HTPC software for my use?
Thank you for your help!
Reply to w0okie
w0okie wrote :
Parts I would like:
- Small casing
Welcome to the Tom's HTPC crowd.
  • You're motherboard is fine unless you want optical S/PDIF. If you need optical digital out, then buy a sound card with S/PDIF. The power supply is fine too, unless you find it too noisy. If too noisy, consider a new PSU by Seasonic, Antec Earthwatts, or Corsair. Doublecheck the front panel pinout on the motherboard where the power button, LED's, etc connect. Some OEM motherboards use a proprietary motherboard header to connect the front panel stuff.
  • Remote? See above.
  • If you already have a PVR, connection options are very limited. Most TV tuners for PC's are designed to pull over-the-air digital or clearQAM digital cable. To pull from a third-party set-top box requires a capture device like the HD-PVR coupled with an IR blaster. Can you verify that you want to capture video from a separate PVR?
  • The best HTPC software is built into Windows 7: Windows Media Center. You can supplement WMC with plugins and addons. See this thread for some tips: link. Media Browser, MyMovies, and XBMC are a very popular front ends that you can use along with WMC to organize and launch your media. You will need playback software for blu-rays. PowerDVD 10 and TotalMedia Theatre 5 are the most popular. You can get TMT5 for $100, and take another 20% off with this coupon code: ARC404P20. If you don't mind not having blu-ray menu support, XBMC can play blu-ray movies and is free. TMT5 and PowerDVD are worth the $$$ because both integrate into Windows and support all blu-ray features like BD-live and menus.
Message edited by rwpritchett on 02-28-2011 at 02:11:18 PM
Reply to rwpritchett
Just want to note that you need some form of software to play Blu-ray disks (no native codecs). I use Cyberlink's Power DVD 10 and it works swell.
------------------------------ Intel Core i3-2120 + EK Supreme HF Full Copper | Gigabyte P67-UD4 | 4x4GB G.Skill Ripjaws X 1600MHz | MSI GTX 560Ti Hawk + Swiftech MCW82 | HWLabs SR-1 120 Rad + DangerDen BIX3 120.3 Rad | Dell P2411H | RAT 5 | WASD Keyboard | Roccat Kave 5.1 Headset
Reply to boiler1990
There are 1899 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1200-1400 Gaming PC - Want Opinions
By Why_Me, 48 minutes ago:
The Z68 boards are older and targeted for Sandy Bridge cpu's. For the newer Ivy Bridge...
Best offers
Top experts
