Do I need cable for NZXT Phantom case USB/eSata/audio?
January 30, 2012 4:15:46 AM
So I'm going to get the NZXT Phantom and Asus P8Z68 gen3 motherboard... the phantom has esata, USB3/2 ports and audio ports built in.. but what do I connect them to the motherboard with?
More about : cable nzxt phantom case usb esata audio
a c 329 V Motherboard
January 30, 2012 8:13:35 AM
No, its coming with the case.
Front panel connections are the standard power/reset switch, power/HD LEDs, one USB, eSATA and front audio connections (HD and AC'97).
On the left is the eSATA...
http://www.overclockersonline.net/reviews/50003281/
m
l
January 30, 2012 8:16:41 AM
So, all u have to do , is connect the wires to mobo.
m
l
a c 87 V Motherboard
January 30, 2012 8:22:59 AM
Use the Manual, and look for the onboard connectors for the respective sockets.
The wires coming from the case will fit onto the mobo and you'll have active FP audio, USB3/2 ports and eSATA.
m
l
January 30, 2012 8:28:15 AM
Thanks! I did check manual for phantom but it is not very good.
Does the esata go into a sata port? I can't imagine needing an esata anything at this point though.
What is meant by HD and AC97?
m
l
January 30, 2012 8:49:40 AM
HD is High Definition Audio and AC97 is the Audio Chip that is used on the board.
You need to go through the Asus Manual and not the Phantoms manual.
m
l
January 30, 2012 8:52:18 AM
What model of the P8Z68 Board are you using?
Deluxe,V,V LE,V LX,V Pro???
m
l
January 30, 2012 9:12:23 AM
I'll probably be getting the P8Z68-V (it's around $170)
m
l
January 30, 2012 9:21:05 AM
If you download the manual for that Board, you'll see the Diagram on the 20th page
m
l
