Need Advice on my Build
Alright, I'm planning on building a new PC that I can use to play mostly RTS games and simple FPS, as well as minecraft :D . Also I'm planning on running a minecraft server for my friend and I only off of it. My budget is around $650 Canadian.
My brother is an internet reviewer and he is able to get me a 400gb SSD and 8gb or ddr3 1333 so im set in that regard.
My Monitors resolution i believe is 800x800 :sol: so i don't need anything crazy for graphics, though i will upgrade my monitor down the road sometime.
There are a few parts that need to be used and are going in no matter what the community says for various reasons. These parts are:
Lian Li PC351b
http://www.ncix.com/products/index.php?sku=41123
Some sort of DVI to VGA adapter.
This is the list of parts I've chosen:
Case: Lian Li PC351b http://www.ncix.com/products/index.php?sku=41123
Mobo: Asus M4A78LT Matx http://www.ncix.com/products/index.php?sku=47948
CPU: AMD Phenom 2 x2 555 http://www.ncix.com/products/index.php?sku=50676
Ram: Not needed, my brother is getting me some for free due to his review connections
HDD: Not needed, my brother somehow managed to land me a 400gb ssd to use in this build :D
PSU: Mushkin Volta 650w http://www.ncix.com/products/index.php?sku=58896
GPU: XFX 5670 1gb http://www.ncix.com/products/?sku=51349&vpn=HD567XZNF3&manufacture=XFX
OS: Windows 7 64bit
Wireless Card: ASUS USB-N13 802.11N USB2.0 Wireless Network Adapter http://www.ncix.com/products/index.php?sku=46387
Monitor: Not needed as i have one around!
This comes out to $634 cdn which is a nice price for me. Please let me know what you think of this build!
1 answer Last reply
More about need advice build
  1. its 800*600 isnt it
    Instead of Mushkin 650W PSU - Get This
    Antec Truepower New 650W Modular Power Supply ATX12V V2.3 Active PFC 80 Plus SLI Ready 120MM PWM Fan
    http://www.ncix.com/products/?sku=36263&vpn=TP-650&manufacture=Antec
    Instead of 5670 - Powercolor Radeon HD 5770 PCS+ 875MHZ 1GB 4.9GHZ GDDR5 2XDVI HDMI DP DIRECTX11 PCI-E Video Card
    http://www.ncix.com/products/?sku=56154&vpn=AX5770%201GBD5-PPGV2%20(AX5770%201GBD5-PPG)&manufacture=PowerColor&promoid=1281
    Only 7$ more gives big time performance
    400GB SSD - THTS COOL
New Build Systems
