So I just bought a new system and put it together. This is what I bought:
AMD Phenom II X4 955 Black Edition
Sony AD7240SGB 24X SATA DVDRW OEM
G.Skill Ripjaws F3-12800CL9D-8GBRL 8GB (2x4GB) DDR3
ASRock 890GX Extreme3 Motherboard
NZXT Phantom Case Black
OCZ Fatal1ty Series 750W Modular
Gigabyte Radeon HD6850 1GB Overclocked
Hitachi Deskstar 7K2000 2TB 7200RPM
When I plugged it in and hit power, absolutely nothing happened. I've checked the power and reset plugs on the motherboard, they are fine, and I've tried them both ways anyway to be sure. I have checked the power switch on the PSU is on, have tried it both ways too. I have checked the wall plug to make sure it is working. I have checked the 24 pin and the 8 pin power connections on the motherboard, they only can go one way and they are plugged in properly. The power plug to the graphics card is in.
Now I have also tried the power button which is physically on the motherboard, pressing that sometimes makes the red light on the power and reset button on the motherboard turn on for a second, then off again.
Anything I might have missed? Any common things with any of the parts that I might have done wrong? I unfortunately don't have a multimeter to start testing the power to each part.
