FIX THE PROBLEM:WARNING!CPU HAS BEEN CHANGED PLEASE RE-ENTER CPU SETTINGS IN THE
Last response: in CPUs
May 31, 2011 8:46:10 AM
please help me fix this
Below are my Cpu settings problem
warning!cpu has been changed.please re-enter cpu settings in Cmos setup and remember to save before quit<what should i do?
Please list the step that i need to do!please!1!!111!!!!
a c 138 à CPUs
May 31, 2011 9:08:29 AM
unplug power AC, remove battery from mobo, let 10minute... put baterry again in mobo
m
l
a c 79 à CPUs
May 31, 2011 9:33:05 AM
or even just enter bios, F2 or Del, and it 'should' auto detect, if not then do what henydiah says and then hits F2/Del to enter bios whilst booting.
m
l
a b à CPUs
May 31, 2011 9:51:07 AM
easiet way of fixing it is,
restart computer, keep taping del key (if thats the key to get into bios)
there should be a recomended options setting select that and then check the settings it chose to make sure there right, save and exit
thats all you really need to know
m
l
a c 103 à CPUs
May 31, 2011 1:02:23 PM
If this is a new cpu on an older motherboard, you may need to upgrade the bios for it to support the cpu.
If not as this is happening everytime you switch pc on, cmos battery is dying and you need to replace it, costs a couple of pounds/dollars etc etc.
Once replace, get into bios and load failsafe defaults, save and exit, then go back in to bios and make any changes you need.
m
l
