5.1ch audio has 5 speakers and a sub-woofer.
2 Front (Left and Right), 2 rear (rear-left and rear-right), 1 centre speaker and a sub-woofer (low frequency such as bass).
I'm not really sure what your problem is.
Have you checked that all the cords are correctly plugged in and that they are plugged into the correct output socket?
Is your audio settings still only set up to use 2.1ch audio?
(You can change this by going to Start > Control Panel > Hardware and Sound > Manage Audio Devices > (select your speakers) > Configure).
Hopefully you can get your speakers working properly.
