Hello!!!
I have Creative Soundblaster Audigy Value installed on my Core2Duo, 2Gb, Windows Vista (x86).
Before installing the Sound Card i used to connect my headphones & mic in the front ports available on my PC cabinet. They used to give good loud sound.
But after installing the Sound Card the front ports were disabled & now i have to connect the headphones on my woofer which gives normal sound on headphones.
So can i use both, the Sound Card & System ports at the same time without any complication.
Thank You!!!
Thank You!!!
