Is seems like it's that time once again to build a new gaming rig. First and foremost this is going to be a Sandy Bridge build so the motherboard is not available yet, but I've listed it below.
The aim of this system is mostly gaming (FPS and some MMOs), at 1920x1080 at the moment, however that may change in the future. I will be purchasing as soon as the motherboard is available.
I will be keeping my Antec 300 as the chassis along with my current 500 GB WD HHD, DVD drive, and heatsink (listed below). I recently bought a new GPU as a part of this upgrade process (XFX HD 6970) so I will list the GPU but I already have that. The parts listed from Amazon are sourced their since we have Amazon Prime .
Motherboard - ASRock P67 Extreme 4
RAM - G.Skill Ripjaw X Series 8gb (2 x 4GB)
CPU - Intel Core i5 2500k
Heatsink - Cooler Master Hyper 212 plus (I already own this heatsink)
GPU - Radeon XFX HD 6970 2 GB (I already own this GPU)
PSU - Corsair HX 850
I will also be replacing the two exhaust fans in my Antec 300 with:
Top Fan - AreoCool Shark 140mm
Rear Fan - AeroCool Shark 120mm
So, do you guys see any glairing issues?
I plan to hopefully add a second HD 6970 down the road, if I do would this PSU be sufficient? Most of what I've read says yes, but I'm not very familiar with calculating PSU requirements.
Finally looking to the future, if I so add a second HD 6970 should I look to replace my Antec 300 case is the airflow sufficient? Currently it run relatively cool, but I'd rather not tempt the heat monster.
