Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Memory > Help choosing ram for this A75itx wifi mobo
Forum Motherboards & Memory : Memory Help choosing ram for this A75itx wifi mobo
Related Content
Can't find your answer?
Ask!
hey there mates!
was looking into getting this mobo:
http://www.newegg.com/Product/Prod [...] 6813500071
and snagging this ram as a matching color combo:
http://www.newegg.com/Product/Prod [...] 6820148482
question:
would i need anything higher than 1866 for a Llano setup? will be getting an A8-3870K hopefully or the 3850.
thanks for taking the time!
------------------------------ WC'ing prjkt | Lutfi's AMS
WC'ing Sticky
Power Supply+UPS
PC Build Guide + Troubleshooting
Reply to Lutfij
You need an mini ATX board ? Because there is better options with less money.
You don't need to buy 1866Mhz memory , its fine with 1333Mhz or 1600Mhz the diference between then you will not observe just in benchmarks.
------------------------------ i7 2600 , AsRock P67 Extreme 6 ,2x4GB Corsair Vengeance 1600 , MSI 6950 2GB , HDD WD 640 AAKS , Corsair 620HX 620W , CPU cooler Zalman CNPS10X Performa , CoolerMaster 912, Philips Led 22"
Reply to sosofm
okay - cos i thought the APU's behaved differently with higher spec'd rams... :/ well if i can get 1600 and pull it off on that mitx board, than yeah i'll give that a go. BTW, i'm building around the SG08 :)
WC'ing Sticky
Power Supply+UPS
Reply to Lutfij
I looked at the specs for that MB, and they clearly say ram is supposed to be DDR3 1866. They don't list 1333 or 1600. If it were me, I would get the 1866 Crucial ram you selected, and not opt for 1333 or 1600 ram.
Reply to abekl
:/ i'm new to the APU - just reading up on other sites about the mobo...and the APU.
WC'ing Sticky
Power Supply+UPS
Reply to Lutfij
sorry for a double post;
http://www.tomshardware.com/review [...] 975-6.html
http://www.legitreviews.com/article/1652/8/
these are what i've been looking for.
Message edited by Lutfij on 02-12-2012 at 03:33:07 AM
WC'ing Sticky
Power Supply+UPS
Reply to Lutfij
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1821 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in installed RAM, computer properties
By smorizio, 43 minutes ago:
windows 32 bit has a 4 gig limit and with parts on the bios shadowing some of the ram...
Best offers
