Hello,
I believe I am having a memory problem. I just put a new system together, and I have been seeing random windows crashes and blue screens. I downloaded 2 memory testing programs, 1 windows, and 1 which runs from a bootable cd-rom. they both report errors, which would make you think it's pretty obviously bad memory right? But then I check in cpu-z, and it seems to say my memory is running at 2000MHz. Screeenshot below. I can't seem to find anywhere in the BIOS to modify this. The only setting in the BIOS is to set the frequency, which is set to 1333MHz.
Motherboard is a ASUS M4A87TD.
CPU is AMD 955BE
Ram is Corsair 2 X 2 GB
Also, the sales guy told me there is no point in getting 1600MHz ram with an AMD, as the AMD chipset will just slow the ram down to 1333 anyway. Is this true?
CPU is AMD 955BE
