Help finding a case/psu for the new rig. P183?
Hey guys, I'm currently working on a new workstation rig for 3d cad modeling/rendering. These are the components im looking at so far! The list is slowly building up as i find more parts! Let me know what you guys think!
2 x e5620 Xeon quad core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117234&cm_re=e5620-_-19-117-234-_-Product
Asus Z8PE-D18
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131379&cm_re=asus_18_dual-_-13-131-379-_-Product
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311&cm_re=240-Pin_DDR3_SDRAM_DDR3_1333-_-20-231-311-_-Product
PNY Quadro fx1800
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133272&cm_re=fx1800-_-14-133-272-_-Product
I'm really interested in the Antec p183 case... will this mother board fit the case? I'm really looking for something plain and simple, nothing flashy that screams gamer!
Also need help looking for a psu.
5 answers Last reply
More about help finding case p183
  1. I've got a P180, its a really nice case, except the for issues that they resolved with the P182/3. It'll take standard ATX cases, but it won't take E-ATX which is the same size as yours, but with a different hole pattern.
    http://forums.anandtech.com/showthread.php?t=280799
    these guys say not.
  2. So i better find another case that will work with the SSI EEB 3.61 Motherboard?
  3. those guys seem to think so, or at least make sure it has the sse eeb 3.61 hole patterns.
    http://www.epinions.com/PC_Cases--motherboard_form_factor_ssi_eeb_3_0
    shows that there are cases out there.
  4. If you like the P183 why don't you get a P193/P193 V3 it will fit E-ATX mobo P183 won't.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129176
    Best psu for a few Antec cases only.
    Antec CP-850 850W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371024
    Fractal Design Define XL Black
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811352005
    Buy a quality psu from Antec,Corsair,XFX,Enermax,Seasonic.
  5. Thanks Davcon! Really loving the simplicity of that case! Thanks for the response! The 193 has that crazy vent on the side that i hate!
Power Supplies Cases Components Product
