recording type
recording bit rate
sampling digital analog choose 98
pole of cable which one to in/out from comp to speaker
memory brand and type ddr1 (highes volt than ddr2 than ddr3) if use onboard soundcard
deferent brand same latecy deferent sound !!! ( it proved if you can perfect set your EQ)
system operation windows xp (best system)
media player : wmp 10 with set EQ and SRS wow and Thru Bass
Soundcard and driver and EQ driver set if any EQ
speaker
any one else ?
best clear sound with componen ; software ; system
best sound card onboard
best memory ( if you have clear speaker and perfect set will deferent)
best media player
recording bit rate
speaker
any one else ?
best media player
