hey I got all the parts and put together my first build trying to double check everything in what i believe was the right manner but now when I start up I have a problem. The problem I have is that the fans from the case arent working. I was slightly confused by how to connect them. They have male and female connectors on them both and I just connected each one directly to the power supply. The bigger issue I have is that when I start up the motherboards processor fan works and the fan on the graphics card works but when I plug them into the monitor I get no display at all. I tried making sure that the card is all the way into the slot by pressing down a little harder but could it be something else? I saw the thread on what to do if you have problems booting up but im unsure is mine a boot up problem or a graphics card problem? Any ideas? Thank u so much
