I've just built a PC using:
Foxconn A74ML-K motherboard
AMD Triple Core Phenom X3 8400 2100MHz CPU
2GB DDR2 800MHz memory
It boots and POSTs fine... until I connect a hard drive to the power supply, at which point the PC will switch on for 1-5 seconds and then switch itself off. I've tried 5 different drives, both ATA and SATA, and it won't work with any of them... although it will work with a DVD drive connected.
It's also being a bit temperamental with a Radeon HD5450 graphics card; sometimes it won't stay switched on until I've removed that as well.
The only component that's not brand new is the power supply, which is a 450W model with 20-pin and 4-pin connectors. The motherboard's manual recommends using one with 24-pin and 4-pin connectors. Does it sound as though I need to replace the power supply, or is there something else going on? There are no beep codes at any point.
Ta
Cliff
I've got a 450W power supply.
Ta
Cliff
