Have just built a system for moderate gaming/bit of CAD/home media and think I went overboard on or am not controlling the fans right.
I have a Coolermaster HAF 922 case with an extra 200mm 19dB side fan (so front/side/top 200s and a 120 std rear). The other fan comes from a Zalman 9900 for the cpu and Sapphire HD5850 card that runs cool. ( Or is it the Power which is a CM 650W)
Problem is even with min. BIOS settings the' fans' run loud at CPU temp 38 degrees C.
Cannot use this as a Media Centre at night when the girl is asleep because the fans overpower the audio.
Is there a fan controller I can get that shuts off most fans except at high CPU temp. Can I have programmabe control over the noise? For use when its a media system? Or drop a fan???
Cheers guys,
Daj
Cheers guys,
Daj
