Hp pavilion magnesium gray edition p6404y power supply upgrade?
hi I was wondering what power supply would be best to fit into my hp pavilion magnesium gray edition p6404y. I'm for looking for something with like 600-700watts affordable but reliable can anyone help? a follow up to that is what graphic card would go well with my wattage for something like world of warcraft.
3 answers Last reply
More about pavilion magnesium gray edition p6404y power supply upgrade
  1. What GPU are you planning on buying? That motherboard only supports one card, so unless it's a dual core monster, you don't need that much power. To answer the first part of your question, you can replace your power supply. It's one of the few things the OEM can't restrict you from doing. Just let us know what graphic card you like on Newegg or whatever, based on you budget, and we'll let you know how much power you need and what companies to buy from.
    without a budget, but within reason:
    Nvidia GTX 560 ti $245
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130634
    CORSAIR Builder Series CX430 430W $45
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
    Nvidia performs better in WoW than AMD/ATI card according to Toms:
    http://www.tomshardware.com/reviews/world-of-warcraft-cataclysm-directx-11-performance,2793-22.html
    Actually what you've given me is perfect just the amount I'd like to spend thanks alot. I do have one last question though. I'm not really experienced with installing PSU (although I've done GPU's) are there any tutorials that could guide me though the process? This would be like my first PSU install.
    Also doesn't the Nvidia GTX 560 ti need a 500 watt PSU?
  3. I'm not going to pretend I spent much time on this, but needless to say it isn't complicated. I simply googled PSU installation for your reference, and I read through a few tutorials.
    The one with the most elaborate information:
    http://compreviews.about.com/od/tutorials/ss/DIYPSU_5.htm
    And my choice for simplicity:
    http://www.youtube.com/watch?v=esWIYzGfbpc
    Honestly, I'm not sure of the minimum requirements. I searched around and all I found was that the Super Clocked version said minimum 500 watts. It won't be much more expensive to change from the PSU I suggested.
    New PSU: CORSAIR Builder Series CX500 V2 500W $60
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Product Components HP Pavilion
