Hi guys,
I've got some problem with my 8800GTS. I regreased it with MX2, and now the fan is stopping when I'm run 3D apps. (I take off the cooler cover and fix an 8cm fan on a cooler, so its "solved") Second big problem is my ambient temp is sometimes jumping in both high and lov temps, like 110 and -60 °C. I'm monitoring the temps with rivatuner and GPU-Z. Core temp is with riva monitor says 72°C max, but with GPU-Z max gpu core temp shows about 110-120°C. Sometimes I see on a GPU-Z monitor a temp jumping on GPU core too. What is the problem?
My comfig : Asus P5Q SE PLUS mobo, E5200 @3.4Ghz CPU, Chieftec GPS-450W PSU, 4x1Gb Kingston hx 1066Mhz mems, 2 hdd, 1 odd, 2x 8cm and 1x12cm fan. CPU temp @ idle is about 30°C max load is 58°C (with intelburntest).
I own this VGA about a year and I didnt got any problem til now.
Here is a riva monitor with marks:
http://img218.imageshack.us/img218/9569/hardwaremonitoring2.png
