Closed
Core Unlock problem...maybe
Last response: in CPUs
June 4, 2011 1:30:45 PM
mobo:Asus M4N68T-M V2
CPU: phenom II X2 560 BE
RAM:2x2GB Mushkin DDR3
GC:ATI HD 4670 1GB DDR3
PSU:Cooler Master Extreme Pwr Plus 460W
CPU cooler:Corsair H50
hello...got problems here. at 1st,core unlock succeed,showed: Phenom II x4 B60 but problem arise after i finished installing graphic card driver..PC shut down itself..when i remove the GC hardware PC work fine..i solved the problem by disabling the core unlock and use default phenom II x2 560..finally can use the GC and PC run normally for a while only :(  ....after installing and played few games: Dirt 3 n Witcher 2 got no problem but after that,when i tried 2 surf the net PC shut down itself again..this time when i press the pwr button only light on and inside looks like the PC is running but PC wont boot...can some1 help me with this??thanx
More about : core unlock problem
June 4, 2011 2:09:25 PM
well i did tried once..and it work..all reset to default..but after a while problem come again..PC automatically shut down(this time i didnt disturb any bios setting)...mayb sometimes the mobo CMOS nid 2 be reset few times?
Score
June 5, 2011 9:59:16 AM
i tried reseating the hardware n problem still persist..sometimes the PC boot up and able to enter desktop then shut down and sometimes only lights n the fans r running but no beeps and post..any suggestion guys?
Score
Best solution
June 5, 2011 11:59:16 AM
Have you tried updating the Motherboards firmware?
Be careful though if you don't know the risks, you can make the motherboard unusable.
I didn't see the issue listed in the fix list but you never know.
http://uk.asus.com/Motherboards/AMD_AM3/M4N68TM_V2/#dow...
June 5, 2011 12:08:15 PM
what if the PC shut down by itself when its trying 2 update the firmware,will it damage the motherboard?
Score
June 5, 2011 3:24:35 PM
If it was in the middle of updating you will have corrupted your BIOS.
People do not advise you to update while in Windows as you never know when something may cause a restart/issue. It is mostly wiser to do BIOS updates from whitin the BIOS/start-up utility.
Most newer motherboards to have a back-up BIOS you can utilise, check the handbook that came with your motherboard to see how to reset to factory default BIOS if you need it.
Score
June 6, 2011 4:48:24 AM
the problem is that even when i did not enter windows and only enter the BIOS, the PC still automatically shut down itself..which hardware could be malfunction?
Score
a c 103 à CPUs
June 6, 2011 10:26:11 AM
Could ber a bad power supply or motherboard.
Score
June 7, 2011 10:34:29 AM
got my PC return back from a technician..he told me the problem was the bios not updated..so he said he flash my mobo bios n for now my PC running fine..my last question..if i tried unlock the core again n my PC not POST or beep..does the updated bios will be gone if i reset CMOS?
Score
a c 103 à CPUs
June 7, 2011 10:41:30 AM
No it will just reset the settings not the version
Score
June 7, 2011 9:22:45 PM
ok...PC still running fine for now..TQ guys :)
Score
June 7, 2011 9:25:20 PM
Best answer selected by jellri.
Score
a b à CPUs
June 7, 2011 9:44:48 PM
This topic has been closed by Mousemonkey
Score
