Closed Solved
Best fans for thermaltake v4?
hi, i am planning on building a new sandy bridge quad core pc in a new thermaltake v4 case.i need advice on choosing the best fans for maximum airflow.i will not be using the fans that came with the case. i need two top 120mm fans,1 front 120mm fan,1 side 120mm fan and 1 rear 120mm exhaust fan.im looking forward to all your suggestions,thanks.also this will be a backup computer with a core i5 2500 with no overclocking and midrange video card setup.i mainly use it for internet surfing,video editing and burning and very light gaming
3 answers Last reply Best Answer
More about best fans thermaltake
  1. Best answer
    Up to you really, depends on how much you want to spend per fan and how loud you want it to be. Look at tje reviews on newegg it will tell you what you want to know.
  2. Best answer selected by kamui4697.
  3. This topic has been closed by Mousemonkey
Power Supplies Fan Thermaltake Components
