I will be building my first solo built gaming rig for the purpose of college/gaming I have no plans of overclocking as of right now and I just need somebody to check part compatibility, whether or not I can add a better sound card in the future,a blue ray drive in the future, and if I can add a second hard drive in the future my budget is around $850 I will be getting it in about 1 month and I have a monitor and keyboard and mouse if I forgot something or if you need more info tell me sorry everything is bunched up
XFX P1-650X-CAG9 650W XXX Edition Modular Power Supply - ATX, 650-Watt, Modular, 80 Plus Bronze, 135mm Fan. "Hard-Core Gamer Compatible"
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5611869&Sku=P450-9204
HP HPDVD1260I Multiformat DVD Writer - DVD+R 24X, DVD-R 24X, DVD+RW 8X, DVD-RW 6X, DVD-RAM 12X, SATA (OEM)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6241266&Sku=L12-1344%20OEM
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Kingston 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model KVR1066D3N7K2/4G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134718
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
ASUS ENGTX460 DirectCU TOP/2DI/1GD5 GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121389
ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131603
APEVIA CF12SL-UBL 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998121
APEVIA X-JUPITER-JR G-Type X-JPJGT-BK Black SECC Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144197
