Wireless Connection
goga44
109
is that whole antenna meant to be outside my Desktop? cant i put it inside or something, i really dont want it externall, and are u sure usb is better than PCI in this?
Its better USB, but it could sit on the desk or the top of the PC, PCI type is weak, that's why it takes so much time to connect, with this its instant.
The smaller one can be plugged in the USB in the back and u don't have to see it.
goga44
109
ok check this motherboard: http://www.novatech.co.uk/products/components/motherboards/intel1155z68chipsetmotherboards/p8z68-vprogen3.html#, can i just put the usb antenna directly into my motherboard usb port?
Yes. U just plug it in the back and it stands right up or to any angle u adjust it.
U don't have to see it at all.
goga44
109
what if i get a PCI USB card which has a internal USB, then i can put it inside my case if it fits
