Solved
First Build Advice
Last response: in Systems
I need a good, fast computer (my mini laptop doesn't cut it) and I want to build it. Ive researched a bit and have taken apart my my old dell, so kinda know what I'm doing, but I need someone who does know what they're doing to check it over. As with every other noob out there.
I would just list off my parts but if you insist I use the template, the fine..... But I will add pictures
Approximate Purchase Date: Want to do it sometime within the week
Budget Range: <800
System Usage from Most to Least Important: Light gaming, Photoshop, and web
Parts Not Required: keyboard, mouse, monitor, speakers... I'll use an old crt for now
Preferred Website(s) for Parts: newegg.com, tigerdirect
Country of Origin: CANADA
Parts Preferences: AMD CPU & Asus mobo
Overclocking: Yes-ish maybe
SLI or Crossfire: Naw
Monitor Resolution: Idk.... pretty low, but it doesn't matter too much
Additional Comments:
From Newegg
AMD Phenom II X2 555 Black Edition Callisto 3.2GH
Got only the dual core b/c this one is easily unlocked to 4 cores, correct?
ASUS M4A88T-M AM3 AMD 880G
This onboard video will be good for now...
Crucial Ballistix 2GB 240-Pin DDR3 SDRAM
SAMSUNG Spinpoint F3 500GB 7200 RPM Bare Drive
LITE-ON Black DVD Writer - Bulk - LightScribe Support - OEM
From Tiger Direct
Ultra LSP550 550-Watt Power Supply
Cooler Master Hyper TX3 CPU Cooler - 92mm
Microsoft Windows 7 Home Premium 64BIT - OEM
NZXT M59-001BK M59 Gaming Mid Tower Case
I wanted something that looks cool for bragging rights lol
Masscool - Thermal Gel Resealable Tube
Total of both carts is $599
I will use the onboard graphics untill I have enough to buy a video card, and when I do it will probly be a $70 ish with dual monitors.
I guess one of my main questions is will I have enough cables, with the dvd being OEM and all, and will the mATX mobo fit in the ATX case? or the 5.5" CPU fan?
Is it a good idea to buy from two different sites? Shipping will be about $20 for tiger and $15 for newegg. I would have gone all newegg but they didn't have some of the things I wanted.
Any help is majorly apperciated.
Жaden
More about : build advice
What I'm doing sounds crazy too. I have 3 sites, Newegg, Tigerdirect, and Amazon. Newegg and Tiger because they have things I want that either has cheaper. But Amazon offers free shipping so thats what I'd do if you want that psu/case/processor/windows 7/fan/case
If you decide to take this path this 500gb hard drive for $25 isn't a bad idea. 25 less than the one you chose. http://www.amazon.com/gp/product/B000R2GC08/ref=ord_car...
I don't have much else to add this is just from my common knowledge of weeks trying to get a perfect gaming build under $800 good luck.
Related ressources
Ask the community
