hi i just finished building my new pc and its my first time building one from scratch
here is my build
asus p9x79 deluxe
i7 3930K
corsair h80 cpu cooler
2 X asus 560ti 1gb dcu2 in sli
16 gb 4*4 ram corsair dominator 16gb qad channel kit (CMP16GX3M4X1866C9)
850 W psu corsair tx850
i managed to connect all the parts in m HAF X case and when i powered up.... the bios came up briefly and spat out some info about my cpu fan not connected....
i turned everything off and when into the case and reconnected the cpu fan cable properly, (i had it upside down i guess)
then i powered up again, this time the screen stays black even though all the led lights in the case and mobo are on.
all fans are working, even the gpu/s are spinning, i tried the dvd drive eject button and the tray pops out too.
just the screen stays in stand by mode, i tried to swap it to the other gpu and same thing...
i noticed the dram led is continuously on on the mobo, i read that it might be a ram problem so i pressed the memok button, the pc restarted a few times and on the second or third time it started bliking faster and then restarted oncemore .
the problem is still the same, the DRAM led stays on continously....
what do i do now guys ? i spent all my money on my new rig and am in desperate need of help
here is my build
asus p9x79 deluxe
i7 3930K
