Heya
I just bought a new PC and I noticed that when I run the specific game ( Silkroad Online ) my PC is making weird noise like a grinding, supposedly it is processor's fan. The strange thing is when I minimize the game ( not closing it) the sound disappears.
When I play Crysis 2 for example everything is fine even though its requirements are much higher than the one that makes troubles.
The noise isnt loud at all but its annoying..Does anyone know what can it be? And is it harmful?
My PC config:
Processor: Intel i7-2600K Sandybridge Socket 1155 CPU-Retail
MOBO: Asus Sabertooth P67 V3 Socket 1155 Sandybridge Intel P67 ATX Intel Motherboard
Case: Coolermaster RC-692-KKn3 CM 692
PSU: THERMALTAKE TPX-775M TOUGHPOWER
Cooler: Corsair Hydro H70 CPU Cooler
Memory: Corsair 16GB 1600MHZ 4x4GB DDR3
HDD: 1TB SATA HDD
SSD 128GB Kingston
Video: Asus GTX 580, 40nm, 4008MHz 1536MB GDDR5, GPU 772MHz, Shader 1544MHz, 512 cores
Thanks in advance!
My PC config:
HDD: 1TB SATA HDD
SSD 128GB Kingston
Thanks in advance!
