Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > I purchase a new motherboard and got this problem
Forum Motherboards & Memory : Motherboards I purchase a new motherboard and got this problem
ok guys so i have this big problem after i install my mb and all i got this
the screen stop on the first like this
**notice this picture from the internet**
http://img214.imageshack.us/img214/4703/img2823ns8.jpg
and got like the error here (floppy disk's fail (40) )
so also at the end it give me
press F1 to continue del to==enter setup
press f8 to safemod
pess F9 to boot device
so when i click on F1 i got this error
http://bloerg.de/media/pic/ReactOS_Bluescreen.jpg
and sometimes i got some screen to format the windows but i got this error:.....the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install windows , Click OK )
and when click f9 to chose the device that iwant to format throgh somebox shows with 3 options (cd/hdd/usb kingston)
and then the pc freeze on this screen and i cant chose any think and the keyboard not respond ..help me what to do i belive that there's somethink i should do on the BIOS what to do ?
Message edited by fawzi on 02-07-2012 at 03:01:36 AM
Reply to fawzi
Hello Fawzi,
don't panic too much this isn't a big problem..
tell me first .. did you install a new motherboard connected to a hard disk and other hardware pieces that were actually connected to another motherboard ??
if so then the corrupted response of the already installed windows is normal especially if it's XP and I think it is because windows 7 can resolve this kind of thing.
about the first screen don't press F1 of course .. first enter you bios and disable the floppy, it won't ask you for it again.
Your screen is a bit confusing because it tells you F1 to enter BIOS .; please know that the bios never displays windows blue error messages .. because the blue screen is talking about an .EXE file and BIOS doesn't really know those things .. the message is pure windows OS KERNEL message linked to a video driver.
and that message actually is linked to an internal graphic card driver. I think the old one of the old motherboard
because when you pressed F1 the bios actually took you to boot from the hard drive and while the hard drive contains already drivers for the old motherboard then windows Got cut.
Try F10 or del to enter the setup not F1 .. if you still unable to display the bios .. which will be strange because the only two cases that doesn't allow you to do so are .. corrupted hardware connected to the machine like (e.g RAM) or a bad keyboard that doesn't work.
enter the bios deactivated the floppy and if it's windows XP then simply restart your system with a windows CD and format everything ..
but if you really reach the safe mode menu then I think you can boot and simply remove the chip set drivers fully .. (.inf files) and evrything linked to the old motherboard .; don't forget the integred soundcard and graphic card drivers too
In my knowledge .. when XP is not really updated with latest services PACK (and sometimes even though) it can't boot if another chipset or motherboard drivers is installed while booting on another.
if you really need what's inside the hard drive then use slave in another machine and copy what you want.
my explanation can be wrong and maybe it's another problem but these information come from my personal experience nothing less or above.
I hope this help
------------------------------ Monster Case - CPU: i7 2600k - Cooler: corsair Hydro 80 - RAM: 16 GB corsair Vengeance
Motherboard: Asus P8P67-M PRO - Graphics: Asus GTX 560 Ti DirectCull 1Go - SSD: OCZ Vertex3 120Gb
HDD: Samsung 500 GB Sata III. Power supply: Gold Corsair AX1200
Reply to SectorC
SectorC wrote :
Hello Fawzi,
YES
i have Windows 7
ok thank you
ok can you till me how can i change this .. to boot me from the cd to format my pc>?**by the way sometimes when i was click on f1 to continue it was log to do format but i was got this error mssge**
http://www.atyab.com/uploadscenter/uploads/df8acc9545.jpg
ok listen when i click F9 to choose the boot device the pc freeze and the keyboard not responde
I hope this help
Reply to fawzi
well actualy as I can see .. the error when you try to format that maybe the last erro made windows enable to understand the file system properly .. in my knowledge you have to format the disk entirely in a slave mode ..
about the bios and freezing the keyboard .. that's something I can't really answer ..
do you have an advanced multimedia keyboard that needs a driver when to use ???
Reply to SectorC
There are 1903 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in installed RAM, computer properties
By smorizio, 56 minutes ago:
windows 32 bit has a 4 gig limit and with parts on the bios shadowing some of the ram...
Best offers
Top experts
