System Specs:
Asus P8P67 Pro B3 Revision 3 Rev. 3.0
Intel i5-2500K 3.3Ghz Sandy Bridge CPU
700W OCZ PSU OCZ700MSXP
4GB DDR3-1600 G. Skill Ripjaws x4
eVGA GTX 460 x2
I was browsing the net a few nights ago, not doing anything intensive whatsoever and my PC just shuts off. It's a custom build that I put together last April. Ok, so first off I'm like "dead power supply already?" Well I tested the PSU and it tested good. I also put in a confirmed good PSU and no luck. The power led comes on on the motherboard. I also noticed the cpu fan and both case fans will twitch when the power switch is first pressed after it's been off for awhile but that's it.
I breadboarded it and tried each individual stick of RAM in the A2 slot one by one. At this point I was down to just the memory, cpu and motherboard. Then I took it down to just the motherboard and cpu. Still no luck, and unfortunately I don't have a case speaker, so I don't have that information to assist me.
There was one thing I found quite interesting during my troubleshooting. Early on while swapping PSUs I forgot to plug the 12V CPU power cable back into the motherboard. When I did this, the fans started up and the computer appeared to be booting up. At this point I still had my boot drive attached and one of my video cards so I plugged my monitor in, turned it on and saw what I expected; "NO SIGNAL". This came as little surprise considering the red CPU LED came on the motherboard when the CPU 12V cable was unplugged.
I am now at the limit of my testing capabilities. I don't have a spare 1155 board or an extra CPU for mine. None of the components ever ran over normal temperatures. I've never even OC'd any of them as I have a backlog of Xbox games to finish up so I haven't really got back to PC gaming yet. I went over the board with a fine toothed comb and couldn't see any obvious issues. I also removed the CPU and examined it. There was no discoloration or any other visible problems. It seems that since I'm down to these two components, it's obviously one or both of them. I was just wondering if anyone might have some advice as to which one I should try to RMA first or maybe both? Perhaps the behavior with the 12V CPU power cable is a clue?
Any advice is much appreciated!
eVGA GTX 460 x2
