Solved
Power supply cables?
Last response: in Components
June 7, 2011 12:52:51 AM
so i just moved from a midsize case to the full size cooler master haf x, which is nice, but the stock power/data cables that came with my modular power supply are barely long enough to connect, much less take advantage of the cable management that the haf x provides.
I can NOT for the life of me, find a bundle of modular power supply cables to buy at all - not even ones the same size as mine. Do they exist? I really do not want to buy all the cables separately.
More about : power supply cables
June 7, 2011 12:57:55 AM
The only real modular cables are from Ultra; the other "modular" PSUs use their own proprietary cables that are usually specific for that PSU or brand.
Depending on how much wattage you need new modular PSUs start at like $60.
m
l
June 7, 2011 1:08:18 AM
well, i actually have an ultra power supply, does that help at all?
m
l
June 7, 2011 1:58:41 AM
Contact Ultra and say if failed if it has a lifetime warranty and they'll send you a new one. Check tigerdirect for the cables.
m
l
June 7, 2011 3:17:09 AM
unfortunately, i need longer cables for all of the ones i have, not a replacement for the same length. i still dont see any cable bundles on tiger, or newegg.
m
l
Best solution
a c 1173 ) Power supply
June 7, 2011 3:48:25 AM
I do see these available from Ultra Products online store :
Ultra U12-40950 X4 Power Supply Replacement Cables for $49.99
Includes:
- 24-Pin Motherboard Power Cable (600mm,16/18AWG) x 1
- 8-Pin + 12V Motherboard Power Cable (600mm,18AWG) x 1
- 4-Pin + 12V Motherboard Power Cable (600mm,18AWG) x 1
- 1 To 2 SATA Power Cables (450mm+150mm,18AWG)x 1
- 1 To 3 SATA Power Cables (450mm+150mm+150mm,18AWG)x 3
- 1 To 2 4-Pin Molex Power Cables (450mm+150mm,18AWG) x 1
- 1 To 3 4-Pin Molex Power Cables (450mm+150mm+150mm,18AWG) x 1
- 1 To 2 4-Pin Molex + Floppy Power Cables (450mm+150mm+150mm,18AWG) x 2
- 6-Pin PCI Express Cables (600mm,18AWG) x 1
- 6-Pin PCI Express Cables (650mm,18AWG) x 1
- 6-Pin PCI Express Cables (700mm,18AWG) x 1
- 8-Pin PCI Express Cables (600mm,18AWG) x 1
- 8-Pin PCI Express Cables (650mm,18AWG) x 1
- 8-Pin PCI Express Cables (700mm,18AWG) x 1
- Case Fan Power Cable (300mm,26AWG) x 1
- Cable Carrying Case
http://www.ultraproducts.com/applications/SearchTools/i...
June 7, 2011 3:54:54 AM
Best answer selected by diru.
m
l
June 7, 2011 3:54:55 AM
wow. i definitely didnt see that, nor did the "ultra" site i looked at look anything like that. must have been a knock off or something. that definitely looks like what im looking for, i need to dig more to find the lengths for them. thanks!
m
l
June 7, 2011 4:03:06 AM
All of the lengths are listed in millimeters followed by the wire gauge (AWG - American Wire Gauge).
You'll need to convert the millimeters to inches if that is what you're looking for.
m
l
